turbine stator and rotor?
Old   May 5, 2011, 14:08
Question turbine stator and rotor?
A V Pantaleao
avpanta is on a distinguished road
Dear colleagues,
I'm trying to simulate a set stator/rotor of a turbine.
I have two separate mesh: a stator mesh with one nozzle and a rotor with two blade (see the image - turbine.jpg). Initially, I used mergeMeshes join the mesh and I put the ggi conditions between stator and rotor mesh. I'm going wrong in this configuration, because my job not run correctly. The case is aborting, and emiting the following message:
Face zone ... name not found. Please check your GGI interface definition.
From function label ggiPolyPatch::zoneIndex() const
in file meshes/polyMesh/polyPatches/constraint/ggi/ggiPolyPatch.C at line 404.
FOAM aborting
Aborted
I would like if is possible to use OpenFOAM 1.6-ext or 1.5-dev for to do this task with no conform mesh and if there is a similar tutorial for this case.
Thank you!
Pantalećo
avpanta is offline   Reply With Quote
Old   May 9, 2011, 01:02
Kurne
kurne is on a distinguished road
Dear A V Pantaleao
Which version of OpenFOAM you are using. If u want to use ggi then it is available only on extension version of OpenFOAM.
Simulation Is Determination Of Imagination Towards Approximation ®
Best Regards
Mubeen K Kurne
kurne is offline   Reply With Quote
Old   May 9, 2011, 07:56
A V Pantaleao
Dear Mubeen K Kurne,
I am trying with OF1.5-dev and 1.6-ext.
Thank you!
Pantalećo
Old   May 9, 2011, 23:54
Kurne
Dear A V Pantaleao
The facezone is not created in the faceZone directory.So first you have to create the faceZone.For creating the faceZone, you follow the section number 9.5.3 mention here http://openfoamwiki.net/index.php/Si...vaned_diffuser .
Hope you will do it.
Best Regards
Mubeen K Kurne
Old   May 16, 2011, 14:52
A V Pantaleao
Dear Mubeen K Kurn,
My case is working now!
obrigado,
Pantalećo
