Home > Forums > OpenFOAM
How to implement power law or hybrid schemes??
Old   May 7, 2011, 17:43
Default How to implement power law or hybrid schemes??
babak kamkari
kamkari is on a distinguished road
Hi every body
I am going to model a flow field in an enclosure by using power law scheme or hybrid scheme.
But in fvScheme I couldn’t find any of these schemes.
As far as I seen in openFoam solvers the most used scheme for divergence discritization are upwind scheme and linear scheme (also TVD, vanleer …). But these two schemes have some defects.
Upwind scheme: this scheme impose artificial dispersion (false diffusion) which Leeds to unrealistic solution.
Linear scheme (central differencing): causes oscillating answer for high Reynolds numbers and unrealistic solution.
Using power law scheme could overcome these infections.
Does anyone know how these schemes could be implemented?
Thanks for consideration
kamkari is offline   Reply With Quote
Old   May 8, 2011, 07:09
Elvis
elvis is on a distinguished road
http://openfoam-extend.svn.sourcefor.../viscoelastic/
http://openfoam-extend.svn.sourcefor...coelasticLaws/
http://openfoam-extend.svn.sourcefor...oelasticModel/
hope this goes in the direction you are looking for.
elvis is offline   Reply With Quote
Old   May 8, 2011, 10:07
babak kamkari
Hi Elvis
Thank you very much for your answer.
I think I couldn’t convey my problem clearly. Power law scheme is not related to viscoelastic modeling. It is on the most famous way for discretizing the convective terms in momentum equation (like second order upwind, central, quick, ...) . It is also one of the special options in Fluent software for discretizing the equations. I couldn’t find this scheme as one of the standard scheme in fvscheme file.
May be it exist in openFoam library with another name!!!!
Old   May 8, 2011, 11:40
Sandeep Menon
deepsterblue will become famous soon enough
Could you point to a published manuscript that describes the scheme? Does it belong to the TVD/NVD family?
Edit: Never mind. Found the sources in Fluent's User Guide. This looks like a relatively straightforward implementation. Derive a class from upwind, compute the local Peclet number, and assign phi_f on a face-by-face basis. The scheme is still first-order, so I'm not sure if there's any real accuracy benefit to this, besides stability.
Sandeep Menon
University of Massachusetts Amherst
http://www.ecs.umass.edu/~smenon
deepsterblue is offline   Reply With Quote
Old   May 8, 2011, 12:13
babak kamkari
Following link is Fluent user guide which explain discretization schemes including power law
http://my.fit.edu/itresources/manual...ug/node992.htm
Old   May 8, 2011, 15:03
babak kamkari
May be it is better to ask which divergence scheme is closer to power law discrertization scheme.
Power law scheme is stable and doesn’t impose false diffusion to the solution. So it can lead to accurate results for convective terms in momentum equation.
Old   May 8, 2011, 17:34
Arjun
arjun is on a distinguished road
This is true only in 1D. Why? Because powerlaw scheme has basis on exact solution of transport equation in 1D. In 2D and 3D though, it loses its shine. Still I am big fan of hybrid schemes, they are much better than upwind type schemes.
arjun is offline   Reply With Quote
Old   May 8, 2011, 23:51
babak kamkari
Hi Arjun
Thank you for your reply,
What kind of div scheme do you recommend for applying hybrid scheme? Having both acuurecy and minimum diffusion
Thank you in advance
Old   May 9, 2011, 00:02
Arjun
Hi Arjun
if you have access to Patankar's book, I think he explains how to impliment powerlaw and hybrid schemes.
He also wrote about how and why one should prefer hybrid schemes over other schemes. That is an interesting read.
Old   May 9, 2011, 09:09
Ben K
benk is on a distinguished road
I'm also interested in knowing how to implement power law/hybrid schemes, since these are the schemes that I've studied before and are well documented in CFD books. A good summary of these schemes is available in the book Versteeg and Malalasekera (An intro to computational fluid dynamics), chapter 5. QUICK is documented in Versteeg (and available in openFOAM) but they say that it may not be stable in certain circumstances.
When I first started to use openFOAM I was surprised not to see these schemes as options, but I also saw schemes that I didn't recognize so I figured that they might be implemented in other ways via blending in some way...still not sure.
benk is offline   Reply With Quote
Old   May 9, 2011, 10:29
Mirko Vukovic
mirko is on a distinguished road
Hi every body
When I was starting out in this field, Patankar's book was also my first reference, and my first code used the hybrid/power-law scheme.
In my second reference, much to my surprise, Ferziger and Peric strongly discourage its use (Computational Methods for Fluid Dynamics p. 64). I learned a lot from reading articles by Prof. Brian Leonard. For example, see (sorry about fonts -- cutting and pasting issues)
Why you should not use ‘Hybrid’, ‘Power-Law’ or related exponential schemes for convective modelling—there are much better alternatives
International Journal for Numerical Methods in Fluids
Special Issue: Numerical Methods for Thermal Problems
Volume 20, Issue 6, pages 421–442, 30 March 1995
As others have mentioned, the power-law/hybrid scheme is good for sourceless 1D convection-diffusion problems.
Once you add sources and move to 2D, you are better off using other methods. Here I defer to others to suggest them.
One of Fluent's basic tutorials (if you have access to it) demonstrates it quite nicely: fluid flow in an bend with a hot fluid added at a second point in the bend. The hybrid solution diffuses the added fluid much more than a second order scheme does.
Mirko
mirko is offline   Reply With Quote
Thread Tools
Trackbacks are On
Non-Newtonian Flow: Power law (2D BFS) hellouch FLUENT 3 April 21, 2009 03:03
Non-Newtonian Power Law for Viscosity John FLUENT 2 September 25, 2008 01:36
about one seventh power law in CFX Eric CFX 3 January 10, 2007 07:16
power law flow through porous media Francesca Chiusa FLUENT 1 November 3, 2006 14:30
Non newtonian power law model in pipe annulus Poly FLUENT 0 March 24, 2005 15:12
