laplacian
Like Tree1Likes
  • 1 Post By Cyp
Old   April 26, 2011, 14:24
Default laplacian
Nima Samkhaniani
nimasam is on a distinguished road
hi foamer
i have a term like this in my equations
del(K del (T))
K is not constant!
which one of following openFOAM expression is correct for above term?
1) fvm :: laplacian ( K,T)
2)fvm::laplacian(K , T) + (fvc::grad(T) & fvc::grad(K))
nimasam is offline   Reply With Quote
Old   April 27, 2011, 06:07
Cyp
Cyprien
Cyp is on a distinguished road
Hi Nimasam !
It is the first expression which is correct otherwise it would be :
K*fvm::laplacian(T) + (fvc::grad(T) & fvc::grad(K))
because you have the following relationship:
fvm::laplacian(K,T) = K*fvm::laplacian(T) + (fvc::grad(T) & fvc::grad(K))
In the programmer guide P-38 you can notice that the laplacian term is coded with the diffusion term which allow you to use a variable diffusion.
Best,
Cyp
tom_flint2012 likes this.
Cyp is offline   Reply With Quote
Old   May 3, 2011, 08:51
Nima Samkhaniani
are you sure following equation sides are equal?
i used both of them in code and i received different answers!
Old   May 3, 2011, 14:13
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
I think it depends on the kind of operation you want to, namely:
1. Implicit (fvm)
2. Explicit (fvc)
3. Mixed treatment
from Programmer's Guide Table 2.2 we have for laplacian:
Laplacian Implicit/Explicit \nabla^2\phi laplacian(phi) (1)
\nabla\cdot\Gamma\nabla\phi laplacian(Gamma, phi) (2)
then both in implicit and explicit treatment we have the operator with and without Gamma within the divergence. In the first case (1) constant gamma is assumed, in (2) laplacian(Gamma, phi) expands in the div-grad formulation intended for variable Gamma. So we have four cases,
a. Explicit, variable Gamma
b. Explicit, constant Gamma (no gamma within the operator)
c. Implicit, variable Gamma
d. Implicit, constant Gamma (no gamma within the operator)
a and b give geometricField as a result and c and d fvMatrix (implying an integration). Reading the code we have in gaussLaplacianScheme.C, for a, b, c
00186 template<class Type, class GType>
00187 tmp<GeometricField<Type, fvPatchField, volMesh> >
00188 gaussLaplacianScheme<Type, GType>::fvcLaplacian
00189 (
00190     const GeometricField<GType, fvsPatchField, surfaceMesh>& gamma,
00191     const GeometricField<Type, fvPatchField, volMesh>& vf
00192 )
00193 {
00194     const fvMesh& mesh = this->mesh();
00195
00196     surfaceVectorField Sn = mesh.Sf()/mesh.magSf();
00197
00198     surfaceVectorField SfGamma = mesh.Sf() & gamma;
00199     GeometricField<scalar, fvsPatchField, surfaceMesh> SfGammaSn = SfGamma & Sn;
00200     surfaceVectorField SfGammaCorr = SfGamma - SfGammaSn*Sn;
00201
00202     tmp<GeometricField<Type, fvPatchField, volMesh> > tLaplacian
00203     (
00204         fvc::div
00205         (
00206             SfGammaSn*this->tsnGradScheme_().snGrad(vf)
00207           + gammaSnGradCorr(SfGammaCorr, vf)
00208         )
00209     );
00210
00211     tLaplacian().rename("laplacian(" + gamma.name() + ',' + vf.name() + ')');
00212
00213     return tLaplacian;
00214 }
00127 template<class Type, class GType>
00128 tmp<GeometricField<Type, fvPatchField, volMesh> >
00129 gaussLaplacianScheme<Type, GType>::fvcLaplacian
00130 (
00131     const GeometricField<Type, fvPatchField, volMesh>& vf
00132 )
00133 {
00134     const fvMesh& mesh = this->mesh();
00135
00136     tmp<GeometricField<Type, fvPatchField, volMesh> > tLaplacian
00137     (
00138         fvc::div(this->tsnGradScheme_().snGrad(vf)*mesh.magSf())
00139     );
00140
00141     tLaplacian().rename("laplacian(" + vf.name() + ')');
00142
00143     return tLaplacian;
00144 }
00147 template<class Type, class GType>
00148 tmp<fvMatrix<Type> >
00149 gaussLaplacianScheme<Type, GType>::fvmLaplacian
00150 (
00151     const GeometricField<GType, fvsPatchField, surfaceMesh>& gamma,
00152     GeometricField<Type, fvPatchField, volMesh>& vf
00153 )
00154 {
00155     const fvMesh& mesh = this->mesh();
00156
00157     surfaceVectorField Sn = mesh.Sf()/mesh.magSf();
00158
00159     surfaceVectorField SfGamma = mesh.Sf() & gamma;
00160     GeometricField<scalar, fvsPatchField, surfaceMesh> SfGammaSn = SfGamma & Sn;
00161     surfaceVectorField SfGammaCorr = SfGamma - SfGammaSn*Sn;
00162
00163     tmp<fvMatrix<Type> > tfvm = fvmLaplacianUncorrected(SfGammaSn, vf);
00164     fvMatrix<Type>& fvm = tfvm();
00165
00166     tmp<GeometricField<Type, fvsPatchField, surfaceMesh> > tfaceFluxCorrection
00167         = gammaSnGradCorr(SfGammaCorr, vf);
00168
00169     if (this->tsnGradScheme_().corrected())
00170     {
00171         tfaceFluxCorrection() +=
00172             SfGammaSn*this->tsnGradScheme_().correction(vf);
00173     }
00174
00175     fvm.source() -= mesh.V()*fvc::div(tfaceFluxCorrection())().internalField();
00176
00177     if (mesh.fluxRequired(vf.name()))
00178     {
00179         fvm.faceFluxCorrectionPtr() = tfaceFluxCorrection.ptr();
00180     }
00181
00182     return tfvm;
00183 }
and for d, from fvmLaplacian.C
00069 template<class Type>
00070 tmp<fvMatrix<Type> >
00071 laplacian
00072 (
00073     GeometricField<Type, fvPatchField, volMesh>& vf
00074 )
00075 {
00076     surfaceScalarField Gamma
00077     (
00078         IOobject
00079         (
00080             "1",
00081             vf.time().constant(),
00082             vf.mesh(),
00083             IOobject::NO_READ
00084         ),
00085         vf.mesh(),
00086         dimensionedScalar("1", dimless, 1.0)
00087     );
00088
00089     return fvm::laplacian
00090     (
00091         Gamma,
00092         vf,
00093         "laplacian(" + vf.name() + ')'
00094     );
00095 }
from the last it is clear that d=c, with Gamma=1. Finally the correct implicit formulation in #1 is
1) fvm::laplacian ( K,T)
formulation given #3
is a mixed one with the spatial variation of T treated implicitly and the spatial variation of K explicitly, the fvc part is put in the RHS, meanwhile fvm part contributes to the matrix, so that it is natural to hope different results (I think).
Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Old   May 9, 2011, 14:45
Nima Samkhaniani
hi Santiago
thank you, for detailed response , now i find why these expressions give different numerical result
now tell me which one of them i should choose for energy equation in two phase flow?
when implicit manner is suitable and when explicit manner is useful?
Old   May 9, 2011, 15:32
I think it is not very different to what is done in scalarTransportFoam solver. That includes variable scalar K (if it is tensorial things change a little bit).
Regards.
Research Scientist
Old   May 9, 2011, 16:04
Nima Samkhaniani
now i add the energy equation into interFoam i even consider evaporation, im just in doubt which one of the above expression is suitable for conduction term?
Old   May 9, 2011, 16:06
The first one.
Regards.
Research Scientist
laplacian
Modifying the laplacian operator mlawson OpenFOAM Running, Solving & CFD 22 July 16, 2018 04:56
How to calculate laplacian of a scalar in cfx? Jun CFX 21 March 2, 2018 09:08
laplacian operatorin udf anon_c Fluent UDF and Scheme Programming 4 August 5, 2013 17:23
why laplacian() failed OFCrash OpenFOAM Running, Solving & CFD 1 February 1, 2010 07:32
Probable bug with laplacian steady state novyno OpenFOAM 1 November 23, 2009 19:31
