-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   fluid/fluid interface type (http://www.cfd-online.com/Forums/openfoam/88295-fluid-fluid-interface-type.html)
fluent_beginner May 13, 2011 02:21
I would like to know if there is any other interface type in OpenFoam instead of directMappedWall. DirectMappedWall will be set as default after executing splitMeshRegions. I think this can only be used for a solid/solid or solid/fluid interface. What kind of type should be used for a fluid/fluid interface? Is there any possibility to get to know all types which can be set maybe by setting a dummy?
Thank you
samiam1000 May 3, 2012 10:33
Dear Foamer,
have you solved it?
And in which file do you define the directMappedWall interface?
And which is the new one?
Thanks a lot,
Samuele
