Flouting point exception twoPhaseEulerFoam - I set delta t
Old   May 16, 2011, 09:28
Default Flouting point exception twoPhaseEulerFoam - I set delta t
cristina87 is on a distinguished road
I receive the Flouting point exception when and I don't know why because I calculated delta t according the formula from tutorial and I set it in controlDict. I have the velocity on OX direction - from 0 to 12 so 13 is the d dimension and I have 20 cells on OX direction => delta x = 0.65. The velocity is (1 0 0) so I set my delta t to 0.65. The Co number I set to be max 0.2. I attached also my case.
Starting time loop
Courant Number mean: 0 max: -0
Max Ur Courant Number = -0
deltaT = 0.65
Time = 0.65
DILUPBiCG: Solving for alpha, Initial residual = 1, Final residual = 6.93889e-18, No Iterations 1
Dispersed phase volume fraction = 7.38636e+295 Min(alpha) = 0 Max(alpha) = 1.1375e+298
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam170/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/opt/openfoam170/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Uninterpreted:
#3 Foam::fv::gaussGrad<double>::grad(Foam::GeometricF ield<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/opt/openfoam170/lib/linuxGccDPOpt/libfiniteVolume.so"
#4 Foam::fv::gaussGrad<double>::grad(Foam::GeometricF ield<double, Foam::fvPatchField, Foam::volMesh> const&) const in "/opt/openfoam170/lib/linuxGccDPOpt/libfiniteVolume.so"
#5 Foam::tmp<Foam::GeometricField<Foam:uterProduct< Foam::Vector<double>, double>::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::grad<double>(Foam::GeometricField<doubl e, Foam::fvPatchField, Foam::volMesh> const&, Foam::word const&) in "/opt/openfoam170/applications/bin/linuxGccDPOpt/twoPhaseEulerFoam"
#6 Foam::tmp<Foam::GeometricField<Foam:uterProduct< Foam::Vector<double>, double>::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::grad<double>(Foam::GeometricField<doubl e, Foam::fvPatchField, Foam::volMesh> const&) in "/opt/openfoam170/applications/bin/linuxGccDPOpt/twoPhaseEulerFoam"
#7 Foam::LimitedScheme<double, Foam::Limited01Limiter<Foam::limitedLinearLimiter< Foam::NVDTVD> >, Foam::limitFuncs::magSqr>::limiter(Foam::Geometric Field<double, Foam::fvPatchField, Foam::volMesh> const&) const in "/opt/openfoam170/lib/linuxGccDPOpt/libfiniteVolume.so"
#8 Foam::limitedSurfaceInterpolationScheme<double>::w eights(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const in "/opt/openfoam170/lib/linuxGccDPOpt/libfiniteVolume.so"
#9 Foam::surfaceInterpolationScheme<double>::interpol ate(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const in "/opt/openfoam170/lib/linuxGccDPOpt/libfiniteVolume.so"
#10 Foam::fv::gaussConvectionScheme<double>::interpola te(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const in "/opt/openfoam170/lib/linuxGccDPOpt/libfiniteVolume.so"
#11 Foam::fv::gaussConvectionScheme<double>::flux(Foam ::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const in "/opt/openfoam170/lib/linuxGccDPOpt/libfiniteVolume.so"
#12
#13
#14 __libc_start_main in "/lib/libc.so.6"
#15
Floating point exception
Cristina
cristina87 is offline   Reply With Quote
Old   May 26, 2011, 15:35
Freeman Adane
freemankofi is on a distinguished road
Cristina,
I think you might probably have an issue with your case setup itself and not the dt based on the error.
Check your BCs, transportproperties, etc to make sure that everything is alright.
BTW, NO test case file was attached to your posting.
freemankofi is offline   Reply With Quote
simpleFoam errors... timestep continuity error/Floating point exception headwing OpenFOAM 1 January 15, 2011 03:04
Help with GNUPlot Renato. Main CFD Forum 6 June 6, 2007 19:51
Env variable not set gruber2 OpenFOAM Installation 5 December 30, 2005 04:27
How to set environment variables kanishka OpenFOAM Installation 1 September 4, 2005 10:15
