Framework of the Mesh
Old   May 19, 2011, 12:33
Default Framework of the Mesh
The True
Eren10 is on a distinguished road
I have mesh generated with Pointwise and this program generates circular mesh frameworks. This means that I can't specify inlet and outlet conditions, so I have the same conditions around the radius of the mesh.
I thought , the circular shape doesn't matter for simulating flows around airfoils.
Now I have doubts about this . I think it should matter, doesn't it ???
generating mesh is easy but I do not know how to change the framework of the mesh.
Eren10 is offline   Reply With Quote
Old   June 7, 2011, 10:27
Default problems due to framework of the mesh
The True
I have convergence problems due to the framework of mine mesh. I am trying to solve this issue with the icoFoam solver.
The framework of the mesh is represented with one patch, so I can't specify inlet/oulet separately ( this would solve my problem).
How should I define this one important patch ? I have used inletOutlet but the system doesn't converge.U file
Flow
type inletOutlet;
inletValue uniform (25 0 0);
value uniform (25 0 0);
p file
Flow
type outletInlet;
outletValue uniform 0;
value uniform 0;
How should I define this patch
Old   June 7, 2011, 10:54
maddalena's Avatar
maddalena
maddalena will become famous soon enough
here is a long thread I started some time ago: http://www.cfd-online.com/Forums/ope...parison-2.html Go through it, around post 35 I started to use a circular domain (generated with fluent, but this does not matter). There is a lot of information on how your bc should be set and some more about convergence issues. Exactly what you are looking for, aren't you ?
mad
maddalena is offline   Reply With Quote
Old   June 8, 2011, 06:22
The True
mad
Thank you for your reply.
Indeed it is almost what I want, only you have 3D case.
For testing I am using icoFoam and than I will go to kepsilon. I am now using inletOutlet for U and p. But still it is not converging. maybe there is a bug in openfoam version 1.7.1
Old   June 9, 2011, 03:23
maddalena's Avatar
maddalena
No bug! Read the thread a little bit more carefully: you should use zeroGradient for p!
mad
Old   June 9, 2011, 16:06
The True
mad
Thank you . I found an other very important problem: the trailing edge is perpendicular to the flow, which gives convergence problems. It seems Openfoam can't handle that part with normal mesh size . Maybe it is a good idea to choose an other airfoil.
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
Meshing aifoil in ICEM student123a ANSYS Meshing & Geometry 13 December 8, 2010 10:40
mesh missing after export in gambit morteza08 ANSYS Meshing & Geometry 1 July 26, 2010 01:10
2d irregular grid Remy Main CFD Forum 1 December 22, 2008 04:49
