Naming blocks in blockMesh
Hi ,
How do i name blocks in a blockMeshDict file ? For example , a line of my blockMesh reads as follows : Code:
blocks Also how do i output the average of this region at every timestep ? Thanks . |
For the first question: you can do it like this:
hex (0 1 2 3 12 13 14 15) Region_1 (20 1 20) simpleGrading (1 1 1) Martin |
Thanks ... How do i output the average of some value , say: gas holdup ,in this region at every timestep ?
I figured out a way to do the same . The code for the same is as follows :
{ Can anyone help me out with this ? |
you must use the reduce command for the zoneVol, too: Code:
Thanks a lot .....
