makeAxialMesh
Old   May 23, 2011, 08:35
Default makeAxialMesh
ata
ata's Avatar
ata kamyabi
ata is on a distinguished road
Hi every one
Can any body tell me why "makeAxialMesh" does not work in OF1.7.0?
Is there an other utility like it in OF1.7.0?
Any help will be appreciated
Ata
ata is offline   Reply With Quote
Old   May 24, 2011, 03:54
Assistant Moderator
Bernhard Gschaider
Originally Posted by ata View Post
Hi every one
Ata
What does "not work" mean? Which version are you using? (the version for 1.5 in the SVN is the most up-to-date version and it works for 1.7.x for me)
Bernhard
Old   May 24, 2011, 04:26
ata
ata's Avatar
ata kamyabi
Hi
I use 1.7.1 and 1.7.0 but I got:
"makeAxialMesh: command not found"
Thanks a lot
Ata
Old   May 24, 2011, 04:40
Nima Samkhaniani
nimasam is on a distinguished road
recompile it again, does it compile properly ?
nimasam is offline   Reply With Quote
Old   May 24, 2011, 06:43
ata
ata's Avatar
ata kamyabi
Hi.
Thank you.
I got it.
Best regards
Ata
Old   May 25, 2011, 02:37
ata
ata's Avatar
ata kamyabi
Hi
I recompiled it. But when I was using it I got this error:
terminate called after throwing an instance of 'std::length_error'
what(): basic_string::_S_create
Aborted
Can any one help me?
Best regards
Ata
Old   May 25, 2011, 03:31
Nima Samkhaniani
download latest version from wiki, i hope it works for u
Old   May 25, 2011, 05:13
Assistant Moderator
Bernhard Gschaider
Hi
Aborted
Best regards
Ata
I have seen that in the past. Usually it is a sign of a compiler mismatch (the compiler used to compile MAM substantially differes from the one used to compile OpenFOAM)
Old   May 25, 2011, 11:36
ata
ata's Avatar
ata kamyabi
Hi
Nima: Thanks a lot. I have latest version.
Bernhard: Thanks a lot. How I can change my compiler in UBUNTU?
Ata
Old   May 25, 2011, 13:06
Nima Samkhaniani
do u use the system compiler or openFoam compiler? you can choose compiler in
etc/settings.sh
below
#compilerInstall=OpenFOAM | System
Old   May 26, 2011, 01:41
  #11
ata
ata's Avatar
ata kamyabi
Hi Nima
I used OpenFOAM compiler. But the problem did not solved. The OpenFOAM compiler is the compiler that OpenFOAM had been compiled with it, isn't it? If I am true, there is no compiler mismatch. So, what is the problem?
Thank you again.
Best regards
Ata
[Other] makeAxialMesh issue feijooos OpenFOAM Meshing & Mesh Conversion 8 October 23, 2014 05:21
Error will loading makeAxialMesh utility in openFOAM-1.6 will_avoid_comm_solvers OpenFOAM 21 October 21, 2014 05:16
makeAxialMesh > collapseEdges!! billynoe OpenFOAM 17 February 21, 2011 04:29
[mesh manipulation] makeAxialMesh for multipleRegions mvoss OpenFOAM Meshing & Mesh Conversion 2 January 5, 2011 08:06
[mesh manipulation] CollapseEdges after makeAxialMesh utility in subversion testcase bonzodeb OpenFOAM Meshing & Mesh Conversion 1 June 5, 2009 03:24
