[Sponsors] | |||||
Thanks Nima,
When i switch from Euler to CrancNicholson in fvScheme, ddt0(U) and ddt0(phi) are Written in time folders. Now, my questions are: 1- is this value equal to D/DT(U)? if no How it can be calculated. 2- Is it any way to write it with Euler ddt scheme? Regards. |
Alberto Passalacqua
Rep Power: 23 ![]() |
Here it is:
DDtU =
fvc::ddt(U)
+ fvc::div(phi, U)
- fvc::div(phi)*U;
Best,
Alberto GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as live DVD/USB, hard drive image and virtual image. GeekoCFD 32bit - The 32bit edition of GeekoCFD. GeekoCFD text mode - A smaller version of GeekoCFD, text-mode only, with only OpenFOAM. Available in a variety of virtual formats. |
Dear Alberto,
Thanks for your answer. Is it possible to describe more. Where should i write this code? What is steps for writing process in time folders? Is it need to define DDT in folder 0? I am running LES with pisoFoam. Regards. |
#6 | |
Alberto Passalacqua
![]() Take a look at createFields.H, where other fields are created, and do something similar for DDtU. Then update the field at the end of the iteration, before runTime.write(). You do not need to do anything in 0 if you specify NO_READ in the IOobject. Best,
#7 | |
![]() it is my first openFoam programming and it was the cause of my silly questions. ![]() Now i have a scientific question. first i describe my works: 1- Copying pisoFoam to new folder pisoFoam2. 2-Adding below code next of U and P IOobject of creatFields.H: Code:
volVectorField DDtU
IOobject
"DDtU",
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::AUTO_WRITE
mesh
DDtU =
fvc::ddt(U)
+ fvc::div(phi, U)
- fvc::div(phi)*U;
EXE = $(FOAM_APPBIN)/pisoFoam2 After this steps and running a case with pisoFoam2 this error is displayed: HTML Code:
Reading field p
Reading field U
--> FOAM FATAL ERROR:
NO_READ specified for read-constructor of object DDtU of class IOobject
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 46.
FOAM aborting
#0 Foam::error::printStack(Foam::Ostream&) in "/home/maysam/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/home/maysam/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 Foam::regIOobject::readStream() in "/home/maysam/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libOpenFOAM.so"
#3 Foam::regIOobject::readStream(Foam::word const&) in "/home/maysam/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libOpenFOAM.so"
#4 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::fvMesh const&) in "/home/maysam/OpenFOAM/OpenFOAM-1.7.0/applications/bin/linux64GccDPOpt/pisoFoam2"
#6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
Aborted
Regards. |
Gregor Olenik
Rep Power: 5 ![]() |
sorry double post
#9 |
Gregor Olenik
hi its because you are using the wrong constructor
look for example at the createfields.H from the coalChemistryFoam Solver Code:
DimensionedField<scalar, volMesh> kappa
IOobject
"kappa",
runTime.timeName(),
mesh,
IOobject::NO_READ,
mesh,
dimensionedScalar("zero", dimless, 0.0)
gregor |
#10 | |
Hi and thanks Gregor
I didn't find its format for vevtor DDtU with dimension [0 1 -2 0 0 0]. Do you know it? Another question for Alberto: Quote:
#11 |
Gregor Olenik
try dimensionedScalar("ddtU", dimVelocity/dimTime/dimTime, 0.0)
edit: well obviously it has to be vector::zero instead of 0.0 Last edited by gregor; June 7, 2011 at 03:52. |
#12 |
volVectorField DDtU
( IOobject ( "DDtU", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::AUTO_WRITE ), mesh, dimensionedVector("DDtU",dimensionSet(0,1,-2,0,0,0),vector::zero) ); ) |
#13 | ||
The problem is solved by: Code:
volVectorField DDtU
IOobject
"DDtU",
runTime.timeName(),
mesh,
IOobject::NO_READ,
mesh,
dimensionedVector("DDtU",dimensionSet(0,1,-2,0,0,0,0),vector::zero)
#15 |
DDtU = fvc::ddt(U) + fvc::div(phi, U) - fvc::div(phi)*U
As it is stated in User guide phi=rho*U So it has problem in dimension. DDtU=>m/s2 ddt(U)=>m/s2 div(phi,U)=div((rho*U)U)=> kg/(m2s2) div(phi)*U=> kg/(m2s2) |
#16 | |
http://www.openfoam.com/docs/user/fv...20-1120004.4.5 But phi which is written in time folders has this dimension: [0 3 -1 0 0 0 0] And with this dimension it has dimension problem yet. div(phi,U)=> m3/s2
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| How to solve in simpleFoam with a volumesourceterm implicity | booz | OpenFOAM Running, Solving & CFD | 3 | March 12, 2009 04:17 |
| How to decide PDE type for 1st order scalar PDE's | shantanu | Main CFD Forum | 28 | June 23, 2008 12:48 |
| Wave Amplitudes for Non-Reflective Boundaries | Richard Wagner | Main CFD Forum | 8 | April 20, 2006 15:35 |
| how to get the particle relative acceleration? | winnie | FLUENT | 6 | June 2, 2003 22:08 |
