Error message when using buoyantSimpleFoam
hi,
i have a big problem when i try to use the function buoyantSimpleFoam. OpenFoam brings me always this error message: almir@ubuntu:~/OpenFOAM/Netz/mittel$ buoyantSimpleFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.7.x | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 1.7.x-3776603e4c6c Exec : buoyantSimpleFoam Date : Jun 01 2011 Time : 18:31:04 Host : ubuntu PID : 2165 Case : /home/almir/OpenFOAM/Netz/mittel nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading g --> FOAM FATAL IO ERROR: cannot open file file: /home/almir/OpenFOAM/Netz/mittel/constant/g at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 61. FOAM exiting almir@ubuntu:~/OpenFOAM/Netz/mittel$ I dont understand that, when i go into the constant-folder there is no file called "g". In my case i have about 300 patches, maybe the high number of patches is the problem. I have unit some of the patches in the boundary conditions (in the 0-folder) with the function boundaryField { "patch[1-358]+" { type fixedValue; value uniform 303.75; // 30.6 degC } maybe this is the problem?? but i also have made a simple example with an easy geometry with only 9 patches and i get same error message. can somebody help me? greets almir |
The error message is telling you that the g file does not exist. Try putting it in the constant directory.
hi Andreas,
thank you! you have solved my problem.:) |
hi,
now OpenFoam brings me a new ErrorMessage: almir@ubuntu:~/OpenFOAM/zylinder$ buoyantSimpleFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.7.x | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 1.7.x-3776603e4c6c Exec : buoyantSimpleFoam Date : Jun 08 2011 Time : 12:34:57 Host : ubuntu PID : 4727 Case : /home/almir/OpenFOAM/zylinder nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading g Reading thermophysical properties Selecting thermodynamics package hPsiThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>> Reading field U Reading/calculating face flux field phi Creating turbulence model Selecting RAS turbulence model kOmegaSST --> FOAM FATAL ERROR: Invalid wall function specification Patch type for patch patch1 must be wall Current patch type is patch From function kqRWallFunctionFvPatchField::checkType() in file derivedFvPatchFields/wallFunctions/kqRWallFunctions/kqRWallFunction/kqRWallFunctionFvPatchField.C at line 47. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam171/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::error::abort() in "/opt/openfoam171/lib/linux64GccDPOpt/libOpenFOAM.so" #2 Foam::fvPatchField<double>::adddictionaryConstruct orToTable<Foam::compressible::RASModels::kqRWallFu nctionFvPatchField<double> >::New(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/openfoam171/lib/linux64GccDPOpt/libcompressibleRASModels.so" #3 Foam::fvPatchField<double>::New(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/openfoam171/applications/bin/linux64GccDPOpt/buoyantSimpleFoam" #4 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::GeometricB oundaryField(Foam::fvBoundaryMesh const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/openfoam171/applications/bin/linux64GccDPOpt/buoyantSimpleFoam" #5 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::readField(Foam::dictionary const&) in "/opt/openfoam171/applications/bin/linux64GccDPOpt/buoyantSimpleFoam" #6 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::readField(Foam::Istream&) in "/opt/openfoam171/applications/bin/linux64GccDPOpt/buoyantSimpleFoam" #7 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::fvMesh const&) in "/opt/openfoam171/applications/bin/linux64GccDPOpt/buoyantSimpleFoam" #8 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::compressible::autoCreateWallFunctionField<do uble, Foam::compressible::RASModels::kqRWallFunctionFvPa tchField<double> >(Foam::word const&, Foam::fvMesh const&) in "/opt/openfoam171/lib/linux64GccDPOpt/libcompressibleRASModels.so" #9 Foam::compressible::autoCreateK(Foam::word const&, Foam::fvMesh const&) in "/opt/openfoam171/lib/linux64GccDPOpt/libcompressibleRASModels.so" #10 Foam::compressible::RASModels::kOmegaSST::kOmegaSS T(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&) in "/opt/openfoam171/lib/linux64GccDPOpt/libcompressibleRASModels.so" #11 Foam::compressible::RASModel::adddictionaryConstru ctorToTable<Foam::compressible::RASModels::kOmegaS ST>::New(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&) in "/opt/openfoam171/lib/linux64GccDPOpt/libcompressibleRASModels.so" #12 Foam::compressible::RASModel::New(Foam::GeometricF ield<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&) in "/opt/openfoam171/lib/linux64GccDPOpt/libcompressibleRASModels.so" #13 in "/opt/openfoam171/applications/bin/linux64GccDPOpt/buoyantSimpleFoam" #14 __libc_start_main in "/lib/libc.so.6" #15 in "/opt/openfoam171/applications/bin/linux64GccDPOpt/buoyantSimpleFoam" Abgebrochen almir@ubuntu:~/OpenFOAM/zylinder$ I think my problem is that i have used for meshing Netgen 4.9.13. this was working quite good, and also the export to OpenFoam Format. But in the constant-folder my boundary-file is looking like that: 9 ( patch1 { type patch; physicalType patch; nFaces 126; startFace 7486; } patch2 { type patch; physicalType patch; nFaces 132; startFace 7612; } and i wont to use the tutorial-files from buoyantCavity for my research, and i have edited them with the patches i have from Netgen. For example i have edited alphat-file like that: FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object alphat; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -1 0 0 0 0]; internalField uniform 0; boundaryField { "patch[4-9]+" { type alphatWallFunction; Prt 0.85; value uniform 0; } "patch[1-3]+" { type alphatWallFunction; Prt 0.85; value uniform 0; } } So my question is how i have to edit the files in the 0-folder (alphat, epsilon, k, mut...)? Or do i have to edit the boundary-file? greets |
