turbulent flow
Old   June 7, 2011, 10:57
Default turbulent flow
s-ammarlu is on a distinguished road
hi everyone
i want to know when a turbulent flow becomes fully development turbulent flow in channels ?
can you help me ?
s-ammarlu is offline   Reply With Quote
Old   June 7, 2011, 11:55
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
The same way you tell a flow is fully developed in real life: when the cross channel velocity profile stops changing as you move down the channel. You'll either need to sample the velocity field at different channel lengths and compare them.
mturcios777 is offline   Reply With Quote
Old   June 7, 2011, 14:28
Default Hi macro
Hi macro
1-i read in a paper , at 30-35 times hydrolic diameter in a channel and after a time , the turbulent flow becomes fully developed , am i wrong ?
2-how can i show diagram velocity ?
3-i dont understand what you say , what time after run 5,10 or 20 or 30 or more seconds ?
spectrum: LES of a turbulent channel flow finally goes to turbulent liu OpenFOAM Running, Solving & CFD 6 November 1, 2011 01:00
Patch a bubble inside turbulent flow Helmi FLUENT 0 February 4, 2011 04:54
Turbulent flow through hexagonal circular pipe yogesh@cfd Main CFD Forum 0 November 9, 2010 23:10
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 05:44
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
