wall Functions based on Aerodynamic roughness
Hello everybody,
I would like to know if there is any available wallFunction in openFoam wich employs the aerodynamic roughness instead of sand roughness for the K-epsilon model o any other turbulence model. Thank you very much in advance. |
Hello!
In the last OpenFOAM release (OF 2.1.1), the announce says: A new nuAtmRoughWallFunction wall function model, specialised for atmospheric velocity profiles has been added in 2.1.1. I glance the code and the new function seems to be using directly the aerodinamic roughnes value of the terrain Z0. So this function, doesn't requires the sand grain value? it can just employ the aeodynamic roughness value? Anyone knows if this is ok? Thankyou very much in advance |
1 Attachment(s)
Within the field of meteorology the usage of z0 is quite common. Normally one uses the Monin-Obukhov relationship, but for incompressible flows with neutral stability (no temperature induced buoyancy effects) this relationship reduces to the common known logarithmic law for rough walls, which could be found in every textbook, e.g. boundary layer theory of Schlichting. z0 is a displacement height, e.g. in small scale simulations it represents a grass layer or in large scale simulations a whole forest. I do not really know what is implemented in nuAtmRoughWallFunction but a logarithmic wall law is really easy to implement. I have attached my version, but it is used for LES (nuSGS). But you should be able to change nuSGS to nut for RANS simulations.
Best regards, Fabian |
1 Attachment(s)
There is a serious bug in the wall function. I fixed it in the attached version.
Dear Fabian,
my target is to perform urban LES, i.e. LES with a rough bounding surface (bottom, building walls, pitched roofs). I would like to use different meteorological roughness lengths for the different types of bounding surfaces. I would like to ask you the following questions:
Best regards, Marcus |
