BubbleFoam
Old   June 8, 2011, 19:32
Default BubbleFoam
Jasmine
Jasmine-s is on a distinguished road
Dear all
I am trying to simulate an air bubble system used for lake aeration with bubbleFoam. The domain is a simple rectangle with air being injected from the bottom of it. The inlet velocity is set to 0.1 and k is 10-6 and epsilon 10-8 (turbulence is on). After a few second the simulation comes to a steady state (velocity and alpha do not change with time), is it because of the k and epsilon values? Or is it because of something else? Also is bubbleFoam the appropriate solver for this problem? Thank you.
Jasmine
Jasmine-s is offline   Reply With Quote
Old   June 10, 2011, 11:37
Sabin Ceuca
sabin.ceuca is on a distinguished road
Hi Jasmine,
what do you mean by "velocity and alpha do not change with time" as it is a vertical domain it should always change due to the difference in density
Perhaps you have a problem with the BC's at the top of your domain.
Regarding your 2nd question you can check twoPhaseEulerFoam aswell, for an exact comparison between these two solvers you can look into the doxygen documentation.
Regards,
sabin
sabin.ceuca is offline   Reply With Quote
Old   June 10, 2011, 16:34
Jasmine
Hi Sabin
Thank you for your reply. Sorry I was not clear before, I meant that the velocity and alpha profile remain unchanged after a while (steady state) , since I am interested to see how the injection of bubbles causes movement in the water I think this solution is not really helpful. I hope I explained it clearly now.
Thank you.
interFoam / bubbleFoam to simulate an aerated tank Meratb OpenFOAM Running, Solving & CFD 3 November 6, 2020 11:45
using bubbleFOAM to model a sludge digester tank Franz_J OpenFOAM Running, Solving & CFD 1 September 30, 2010 22:09
Inputs for bubbleFoam rans2009 OpenFOAM 0 October 8, 2009 07:59
bubbleFoam rans2009 OpenFOAM 3 October 5, 2009 04:28
Lift force modeling in bubbleFoam holger_marschall OpenFOAM Running, Solving & CFD 2 December 10, 2007 15:24
