-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   SIGFPE Error - Need help! (http://www.cfd-online.com/Forums/openfoam/89312-sigfpe-error-need-help.html)
newOFuser June 9, 2011 09:15
I am a new OF user, and was trying to use the reactingFoam solver (slightly modified) to study combustion in a cylindrical swirl combustor. However, after a few time steps I got the error below.
Could someone please point out what could be causing this floating point exception, and how to rectify it?
Thank you so much!
ak
Time = 0.0124618
Solving chemistry
[24] #0 Foam::error::printStack(Foam::Ostream&)diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
in "/home/ak/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libOpenFOAM.so"
[24] #1 Foam::sigFpe::sigFpeHandler(int) in "/home/ak/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libOpenFOAM.so"
[24] #2 in "/lib/libc.so.6"
[24] #3 in "/lib/libm.so.6"
[24] #4 pow in "/lib/libm.so.6"
[24] #5 Foam::ODEChemistryModel<Foam::psiChemistryModel, Foam::sutherlandTransport<Foam::specieThermo<Foam: :janafThermo<Foam::perfectGas> > > >::omega(Foam::Reaction<Foam::sutherlandTransport< Foam::specieThermo<Foam::janafThermo<Foam::perfect Gas> > > > const&, Foam::Field<double> const&, double, double, double&, double&, int&, double&, double&, int&) const in "/home/ak/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libchemistryModel.so"
[24] #6 Foam::ODEChemistryModel<Foam::psiChemistryModel, Foam::sutherlandTransport<Foam::specieThermo<Foam: :janafThermo<Foam::perfectGas> > > >::tc() const in "/home/ak/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libchemistryModel.so"
[24] #7
[24] in "/home/ak/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linux64GccDPOpt/pFoam"
[24] #8 __libc_start_main in "/lib/libc.so.6"
[24] #9
[node86:15576] *** Process received signal ***
[node86:15576] Signal: Floating point exception (8)
[node86:15576] Signal code: (-6)
[node86:15576] Failing at address: 0x58f800003cd8
[node86:15576] [ 0] /lib/libc.so.6(+0x33af0) [0x2acc4f3dcaf0]
[node86:15576] [ 1] /lib/libc.so.6(gsignal+0x35) [0x2acc4f3dca75]
[node86:15576] [ 2] /lib/libc.so.6(+0x33af0) [0x2acc4f3dcaf0]
[node86:15576] [ 3] /lib/libm.so.6(+0x13e81) [0x2acc4ef21e81]
[node86:15576] [ 4] /lib/libm.so.6(pow+0x15) [0x2acc4ef33765]
[node86:15576] [ 5] /home/ak/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libchemistryModel.so(_ZNK4Foam17ODEChemistryModelI NS_17psiChemistryModelENS_19sutherlandTransportINS _12specieThermoINS_11janafThermoINS_10perfectGasEE EEEEEE5omegaERKNS_8ReactionIS8_EERKNS_5FieldIdEEdd RdSI_RiSI_SI_SJ_+0x285) [0x2acc4dca9ff5]
[node86:15576] [ 6] /home/ak/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libchemistryModel.so(_ZNK4Foam17ODEChemistryModelI NS_17psiChemistryModelENS_19sutherlandTransportINS _12specieThermoINS_11janafThermoINS_10perfectGasEE EEEEEE2tcEv+0x57e) [0x2acc4dcb524e]
[node86:15576] [ 7] pFoam() [0x426bf3]
[node86:15576] [ 8] /lib/libc.so.6(__libc_start_main+0xfd) [0x2acc4f3c7c4d]
[node86:15576] [ 9] pFoam() [0x421119]
[node86:15576] *** End of error message ***
djstoneage June 15, 2011 02:31
i do unset sigfpe and it works but not too sure if it is the right way of doign things? try to check your initial conditions
newOFuser June 15, 2011 08:39
Thanks for your reply! How did you unset this option?
I tried "unset FOAM_SIGFPE" in the .bashrc file followed by the “. $HOME/.bashrc” command, but when I run the case, I still get the following before the simulation starts:
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
SetNaN : Initialising allocated memory to NaN (FOAM_SETNAN).
I tried "export FOAM_SIGFPE=false" as well but that didn't work either.
-ak
djstoneage June 19, 2011 22:55
unset FOAM_SIGFPE
Just type unset FOAM_SIGFPE in your case directory in terminal
newOFuser June 20, 2011 09:28
Thanks so much!
As you pointed out earlier, I am also looking at choosing appropriate conditions and fvschemes to avoid getting the error.
Thanks again
ak
djstoneage June 20, 2011 12:30
try checking your initial condition. in my case i found when i set values to my initial condition i am able to avoid the sigfpe error. what study are you doing? I am a little problem with my atmospheric wind studies
newOFuser June 20, 2011 12:34
Sure, thanks so much!
I found that changing the fvSchemes and reducing relaxation factors in fvSolution file can also have a significant effect.
I am looking into premixed combustion studies at present.
djstoneage June 20, 2011 12:51
i checked the relaxation factor but it run for a few iteration and after a certain iteration it will get the sigfpe error again. do you have any experience with atmospheric wind studies? right now i've got the boundary layer figure out but, the flow doesnt seem to go though my off shore platform that im looking at
newOFuser June 20, 2011 12:54
sorry, i don't...
tgvosk October 6, 2012 16:01
Bug Report #0000657
I know this is an old thread, but I had a very similar problem with a sigFpe in reactingFoam that was solved by the fix pushed in Bug Report #0000657. If you (or anyone) are still having this problem, maybe that will fix it.
I was getting the sigFpe from the exact same function as your error log shows (and found this thread while trying to figure out what was wrong).
amcloughlin801 February 5, 2016 02:44
Reset FOAM_SIGFPE
I have unset SIGFPE and now I want to reset it again. Does anyone have any idea how I would do that?
