Home > Forums > OpenFOAM
Grid conversion from Pointwise to OpenFoam
Old   June 10, 2011, 08:20
Default Grid conversion from Pointwise to OpenFoam
Gitesh
Gitesh P is on a distinguished road
Hello everyone
I am new at OpenFoam. Can anyone explain me how to convert grid from Pointwise to OpenFoam step by step ?
Thank you in advance.
With regards,
Gitesh
Gitesh P is offline   Reply With Quote
Old   June 10, 2011, 08:45
Awais Ali
owayz is on a distinguished road
Send a message via MSN to owayz
Pointise has option to directly export grid for OpenFoam. So I think there is no need for any conversion.
All you have to do is to create the mesh properly in openfoam and you are done.
owayz is offline   Reply With Quote
Old   June 11, 2011, 02:43
Gitesh
Thank you for your reply.
OK. But I have very complex grid which is generated in Pointwise. So, I want
to use it directly in OpenFoam by just conversion.
With regards,
Gitesh
Old   June 11, 2011, 15:42
Bill Rosemurgy
brosemu is on a distinguished road
Pointwise "knows" the OpenFOAM format.
Under the CAE menu, select "Select Solver" and choose OpenFOAM.
Re-check your boundary patch types and make sure they are what you were hoping.
Select all of the blocks and go to File --> Export --> CAE, navigate to a run directory, choose the "polyMesh" folder in the "constant" directory and click export. Wait a minute or two, Pointwise will create the faces, points, owner, neighbor, .... files that OpenFOAM needs.
brosemu is offline   Reply With Quote
Old   June 22, 2011, 08:56
Gitesh
Thank you for your explanation. But still there are some confusion. Sorry but I am new at this work station.
OK. For example I have mesh file from pointwise.
Then I make case directory in OpenFoam then create empty constant, system, and o(zero) ones.
Also polyMesh in side constant. Then what to do next ???
With regards,
Gitesh
Old   June 22, 2011, 10:16
Awais Ali
Then you go to Export in pointwise. May be it would say export "Solver Data" ..
And then you go to the case directory and export the mesh. You don't have to go anywhere else you just export your mesh in the case directory and it will automatically be exported in 0 folder or the contant/polymesh folder.
Regards,
AWais
Old   June 23, 2011, 14:04
Bill Rosemurgy
Follow these instructions:
Open the mesh file in Pointwise.
Thread Tools
Trackbacks are On
Native OpenFOAM interface in Pointwise cnsidero OpenFOAM Meshing & Mesh Conversion 41 May 20, 2012 18:30
OpenFOAM Training in Europe and USA hjasak OpenFOAM 0 August 8, 2008 05:33
OpenFOAM Debian packaging current status problems and TODOs oseen OpenFOAM Installation 9 August 26, 2007 13:50
Conversion variable profiles to OpenFoam initialization BC profiles and mapFields vvqf OpenFOAM Pre-Processing 1 February 14, 2006 10:08
GRID TO GRID INTERPOLATION in FLUENT calogero FLUENT 3 June 4, 2003 08:32
