-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   renumberMesh (http://www.cfd-online.com/Forums/openfoam/89515-renumbermesh.html)
pere June 15, 2011 04:37
renumberMesh
I made renumberMesh -constant -overwrite for calculate with 90 procs went I made decomposePar there is no problem, but when I made mpirun -np 90 buoyantBoussinesqSimpleFoam -parallel > log I receive this error:
0]
[0]
[0] --> FOAM FATAL IO ERROR:
[0] keyword SIMPLE is undefined in dictionary "/tmp/ppuigdom/snappy24/processor0/../system/fvSolution"
[0]
[0] file: /tmp/ppuigdom/snappy24/processor0/../system/fvSolution from line 22 to line 62.
[0]
[0] From function dictionary::subDict(const word& keyword) const
[0] in file db/dictionary/dictionary.C at line 456.
[0]
FOAM parallel run exiting
[0]
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
mpirun has exited due to process rank 0 with PID 583140 on
node pirineus exiting without calling "finalize". This may
have caused other processes in the application to be
terminated by signals sent by mpirun (as reported here).
--> FOAM FATAL ERROR:
No times selected
From function reconstructPar
in file reconstructPar.C at line 107.
FOAM exiting
Anyone knows where's the problem?
thanks
nsf June 15, 2011 12:40
Maybe I'm pointing out the obvious:
Does you system/fvSolution contain the keyword SIMPLE?
If not have a look at the tutorial case for buoyantBoussinesqSimpleFoam
Best Regards
wyldckat June 25, 2011 07:51
Greetings to all!
The other issue might be that renumberMesh should also have been executed in parallel as well:
mpirun -np 90 renumberMesh -constant -overwrite -parallel
Best regards,
Bruno
Attesz May 9, 2012 06:05
Dear Bruno,
could you explain me a bit about renumberMesh? What is it for?
Thanks,
Attila
wyldckat May 9, 2012 08:52
Hi Attesz,
Search -> Advanced search:
  • Keyword(s): renumberMesh
  • User name: wyldckat
Results -> second link: http://www.cfd-online.com/Forums/ope...tml#post341181
Originally Posted by wyldckat (Post 341181)
The mesh present in "constant/polyMesh" gets renumbered into a more diagonal form for the "A.x=B" system.
Best regards,
Bruno
