solver
Old   June 17, 2011, 05:00
Default solver
venkat
venkataramana is on a distinguished road
dear Foamers,
which solver is suitable for the following application:
The flow and heat transfer problem of a fluid film over an unsteady stretching sheet is
considered. The fluid is incompressible
thanks in advance.
venkataramana is offline   Reply With Quote
Old   June 17, 2011, 05:17
Post Hello Venkat,
T. Chourushi
Tushar@cfd is on a distinguished road
For the above mentioned problem, bouyantBoussinesqPisoFoam suits best. It's quite simple and fits in your requirements.
_______
Regards,
Tushar@cfd is offline   Reply With Quote
Old   June 17, 2011, 06:47
venkat
hi tushar,
where the above solver is located, i am unable to find it , but i found bouyantBoussinesqsimpleFoam under heat transfer folder.
thanks for reply.
Old   June 17, 2011, 07:03
venkat
hi Foamers,
here i am defining the problem, which solver suits for the following problem:
An analysis is made of the temperature distribution and velocity in
the flow of a viscous incompressible fluid caused by
the stretching of a sheet which issues from a slit in to
the fluid.
Due to entrainment of the ambient
fluid, this boundary layer is different from that in the Blasius
flow past a flat plate.
Regards,
Venkat.
Old   June 17, 2011, 07:11
Default Hello Venkat,
T. Chourushi
I don't know which version of OpenFoam you are using. Anyways, "OpenFoam_1.6" has this solver. I am attaching those files with this thread for your further progress.
buoyantBoussinesqPisoFoam.zip
buoyantBoussinesqPisoFoam_tut.zip
Old   June 17, 2011, 07:19
venkat
i am using opefoam 1.71 version
Old   June 17, 2011, 23:44
Post Hi venkat,
T. Chourushi
It's ok, just use those files in OpenFoam 1.7.1, it will work all fine...
cya
Old   June 18, 2011, 00:33
venkat
hi Tushar,
thanks for your reply,
in this problem the sheet (flat plate) also moving with some velocity, so that the boundary layer is different from that of fixed flat plate, how it is similar to hot room problem.
Old   June 18, 2011, 12:42
Post Hi venkat,
T. Chourushi
Can you send me your case I will sort out your problem.
Old   June 18, 2011, 22:24
Default hi Tushar
venkat
Here I am attaching the physical model,
Old   June 19, 2011, 01:02
Post Hi venkat,
  #11
T. Chourushi
Just change the BCs, it will work.. anyways I would have admire if you would have provided me the case files. I mean I could have done the changes and could have emailed you..
A New Solver for Supersonic Combustion nakul OpenFOAM Announcements from Other Sources 19 February 27, 2024 09:44
[Other] A New Solver for Supersonic Combustion nakul OpenFOAM Community Contributions 20 February 22, 2019 09:08
thobois class engineTopoChangerMesh error Peter_600 OpenFOAM 4 August 2, 2014 09:52
Development of a Low mach PISO solver nishant_hull OpenFOAM Programming & Development 0 August 25, 2009 12:48
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 14:08
