Benchmark for Fluid-Structure Interaction solver (IcoFsiFoam)
Old   June 17, 2011, 11:30
Default Benchmark for Fluid-Structure Interaction solver (IcoFsiFoam)
Antoine H.
Eferal is on a distinguished road
Greetings everyone,
I've been working on this benchmark : http://onlinelibrary.wiley.com/doi/1...3.0.CO;2-1/pdf
I use openfoam-1.5-dev and the IcoFsiFoam solver. I run the same simulation than the pdf paper, but I don't have the same results. I changed a lot of parameters like timestep, my mesh, fvsolution ... but the displacement of the beam structure is not bigger than 0.1 meter.
Does anyone else encounter some issues with this IcoFsiFoam solver ? Anyone interested in running this simulation and try to figure out what's wrong ?
Thank you very much in advance,
Antoine
Eferal is offline   Reply With Quote
Old   June 17, 2011, 15:09
Andreas Feymark
feymark is on a distinguished road
I have been testing icoFsiFoam a bit. My guess is that there is a problem with the interpolation. As I understand it the interpolation routine (patchToPatchInterpolation) is based on a ray-search algorithm, this algorithm results in a problem if the solid is thin in relation to the cell size. However, this is not the only problem, even thou i think it's the biggest one in this particular case. See for example http://www.cfd-online.com/Forums/ope...-problems.html
Take care,
FEYMARK
feymark is offline   Reply With Quote
Old   June 17, 2011, 15:13
Andreas Feymark
I can try to run the simulation and help you with corrections if you provide me with the case.
/FEYMARK
Old   October 3, 2013, 03:04
Vincent
VincentChai is on a distinguished road
Hi FeyMark,
i am currently trying the icoFsiFoam with the benchmark case which Antoine was mentioned, i have tried with the tutorial provided in OpenFoam for icofsifoam as well. However, the tutorial can get a magnitude of 1e-3m but the benchmark test cannot.
May I know have you tried the icoFsiFoam with the benchmark case already? Hope that you can help me in this work.
Thanks.
Vincent
VincentChai is offline   Reply With Quote
two way fluid structure interaction mike CFX 10 November 21, 2012 15:37
Fluid Structure Interaction Apollo Main CFD Forum 5 July 4, 2011 16:15
fuid structure interaction stk FLUENT 1 November 10, 2005 14:13
FLUID STRUCTURE INTERACTION Javier FLUENT 1 October 14, 2004 13:42
compressible two phase flow in CFX4.4 youngan CFX 0 July 1, 2003 23:32
