error with icoDyMFOAM; how to set face extrusion zones
Old   May 9, 2011, 03:35
Default error with icoDyMFOAM; how to set face extrusion zones
koji kiyono
kiyono is on a distinguished road
Hello.
I am trying to set up a case in OpenFOAM-1.5-dev and run it using icoDyMFoam, but the solver doesn’t work well.
When I run the solver it gives me the following error:
| \\ / O peration | Version: 1.5-dev |
| \\ / A nd | Revision: exported |
| \\/ M anipulation | Web: http://www.OpenFOAM.org |
Exec : icoDyMFoam
Date : May 09 2011
Time : 00:11:07
Host : ubuntu
PID : 7177
Case : /home/kiyono/OpenFOAM-1.5-dev/applications/solvers/incompressible/icoDyMFoam/Topo2D2
nProcs : 1
Create time
Create dynamic mesh for time = 0
Selecting dynamicFvMesh movingConeTopoFvMesh
--> FOAM Warning :
From function dlLibraryTable:pen(const dictionary& dict, const word& libsEntry, const TablePtr tablePtr)
in file /build/buildd/openfoam-dev-1.5-1726/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude/dlLibraryTableTemplates.C at line 68
library "libtopoChangerFvMesh.so" did not introduce any new entries
Updating vertex markup. curLeft: 0.004 curRight: 0.008
Time = 0
Adding zones and modifiers to the mesh
zone: 0()
zone: 0()
Adding mesh zones.
Face extrusion zone contains no faces. Please check your mesh definition.
From function void Foam::layerAdditionRemoval::checkDefinition()
in file polyMeshModifiers/layerAdditionRemoval/layerAdditionRemoval.C at line 88.
FOAM aborting
Although I set up a case similar to movingConeTopo in the tutorials, face extrusion zone contains no faces in my case. What is the problem?
Any help you can provide will be kindly appreciated.
kiyono is offline   Reply With Quote
Old   June 17, 2011, 15:07
Sarah
SMesser is on a distinguished road
Still working on a similar problem, but here's another thread that may point folks like me in the right direction.
SMesser is offline   Reply With Quote
[blockMesh] Internal walls of zero thickness anger OpenFOAM Meshing & Mesh Conversion 23 February 6, 2020 18:25
Face Set Constructor for star v4.02 gonnafon Siemens 1 June 6, 2012 09:16
Viewing Face Zones Naghman Khan FLUENT 1 September 24, 2007 16:23
WARNING: non-positive face area exist. Alan Main CFD Forum 4 August 17, 2006 07:33
