dynamicRefineFvMesh
Old   June 21, 2011, 13:52
Default dynamicRefineFvMesh
Nima Samkhaniani
nimasam is on a distinguished road
dynamicFvMesh dynamicRefineFvMesh;
dynamicRefineFvMeshCoeffs
refineInterval 1;
field alpha1;
lowerRefineLevel 0.001;
upperRefineLevel 0.999;
unrefineLevel 10;
nBufferLayers 1;
maxRefinement 2;
maxCells 200000;
correctFluxes
phi
U
dumpLevel true;
hi foamer could you please tell me the meaning of :
unrefineLevel and nBufferLayers and dumpLevel ?
thanks alot
nimasam is offline   Reply With Quote
Old   June 25, 2011, 16:01
Nima Samkhaniani
any update?
Old   August 22, 2013, 03:03
Default Partial Answer
Christian Butcher
chrisb2244 is on a distinguished road
So I'm also looking into this, because I don't know what the unrefineLevel refers to, but the example dynamicMeshDict at $FOAM_SRC/dynamicFvMesh/dynamicRefineFvMesh/dynamicMeshDict has lots of useful comments.
In particular,
"//Which cells to un/refine:... unrefine pointCells that are within nBufferLayers of points marked for refinement."
My understanding of this (which may be wrong :/) is that the cells within nBufferLayers of cells which have the field value specified by the "field" variable between "minLevel" and "maxLevel" will be examined for unrefinement, if they do not have a value falling between min/max level.
If you know the meaning for unrefineLevel, please let me know.
The file taken from the tutorial "damBreakWithObstacle" has
"//If value < unrefineLevel unrefine
unrefineLevel 10;"
but since the values sought out are between 0.001 and 0.999 I would assume this would unrefine every point?
chrisb2244 is offline   Reply With Quote
dynamicrefinefvmesh
dynamicRefineFvMesh on polyhedral meshes lr103476 OpenFOAM Running, Solving & CFD 5 May 11, 2020 12:03
map point Fields in dynamicRefineFvMesh lukasfischer OpenFOAM Running, Solving & CFD 9 October 26, 2012 10:06
dynamicRefineFvMesh/ solidBodyMotionFvMesh FG_HSRM OpenFOAM 3 July 19, 2012 12:39
dynamicRefineFvMesh in 2 directions Victor OpenFOAM 6 June 28, 2010 05:46
Problem with leastSquares scheme when using dynamicRefineFvMesh christian_kunkelmann OpenFOAM Running, Solving & CFD 2 July 10, 2009 11:19
