Is it suitable to use Weller's scheme in this case?
Old   June 17, 2011, 16:16
Default Is it suitable to use Weller's scheme in this case?
Kai
kaifu is on a distinguished road
Hi Foamers,
In order to strictly restrict alpha in [0,0.52], I am now considering to use MULES in case of bubbly flow. I have a question here since in Weller's scheme, there is a compression term (eqn 4.13, Rusche). And it is said "The arti ficial term is only active in the thin interface region because of the multiplication term gamma(1-gamma)". It is true in case of liquid-vapor with clear interface which only exists somewhere. However in bubbly flow, the interface could be everywhere. I dont know if it is appropriate to use this scheme in my case. Thanks.
// Kai
kaifu is offline   Reply With Quote
Old   June 21, 2011, 16:56
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Originally Posted by kaifu View Post
Hi Foamers,
// Kai
Are you considering the bubbles interface as a dispersed interface or tracking each bubble's shape?
Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Old   June 21, 2011, 18:03
Kai
I do not track bubbles interface. As you said, the bubbles interface is treated as a dispersed interface.
Kai
Old   June 21, 2011, 18:08
Hi, MULES and interfaceCompression are intended for VOF problems in which surface is completely described and tracked. Maybe you can explain your case a little bit in order to see if it is possible to use these techniques in your case.
Regards.
Research Scientist
Old   June 22, 2011, 05:43
Kai
It is a two-phase Euler-Euler case. And I think the the way you define the compression term is different between the interface-tracking and dispersed interface (eqn 3.58 and eqn 4.13, Rusche). In my case, there are two velocity fields: Ua and Ub, instead of the single velocity field in the interface-tracking case.
Kai
Old   June 22, 2011, 08:09
Patricio Bohorquez
pbohorquez is on a distinguished road
Just run simple benchmarks to compare with analytic solutions and see what happens. I feel you will be happy with your results.
Hi Foamers,
// Kai
pbohorquez is offline   Reply With Quote
bc's of a komegaSST case Zymon OpenFOAM 11 July 25, 2010 09:36
Need help to open an OpenFoam case with Paraviw aaurouss OpenFOAM 2 July 6, 2009 13:18
Time discretisation scheme for steady state case Andrey CFX 7 September 16, 2008 03:40
extrapolation in MUSCL scheme Chandra Main CFD Forum 6 February 14, 2007 11:21
Roe Scheme; Shock Boundary layer Interaction Mohammad Kermani Main CFD Forum 5 December 20, 1999 15:44
