Flow in a tube with heat transfer.
Old   June 22, 2011, 02:45
Default Flow in a tube with heat transfer.
Marco Bernardes
masb is on a distinguished road
I'm planning to simulate a flow in a tube with heat transfer. Which solver is the most appropriated?
Thanks in advance,
Marco.
masb is offline   Reply With Quote
Old   June 22, 2011, 02:51
Marco Bernardes
must be turbulent.
Thanks,
Marco.
Old   June 22, 2011, 08:31
Samuel ARNAUD
sixwp is on a distinguished road
It depends what you want to solve:
- If it's just the forced convection in the tube, I would recommend you the solver buoyantSimpleFoam.
- If you also want to simulate the conduction in the tube layer, better use a multi-regions solver as chtMultiRegionSimpleFoam.
Though, it might be different given your case: Is it subsonic? Does radiation matter? etc...
Please, give more details of it for further help.
PS: and have a look at the wiki and the forum search function
Have a nice day
Sam
sixwp is offline   Reply With Quote
Old   June 22, 2011, 08:38
Marco Bernardes
Hi Sixwp,
Thank you for the reply. Actually I'm planning to simulate just subsonic forced convection. No radiation. Then buoyantSimpleFoam is the best option, ok?
Many thanks,
Marco.
Old   June 22, 2011, 18:04
Default The flow should be internal.
Marco Bernardes
Hi Sam,
The flow should be internal forced convection in a tube. No buoyancy is needed.
Regards,
Marco.
Old   June 23, 2011, 10:26
Logan Page
Logan Page is on a distinguished road
Hi
Buoyancy will have a negligible effect in most cases unless you have two phase flow.
If you want T and U to be uncoupled (i.e. no buoyancy effect) you can easily modify say the simpleFoam solver to include the energy equation.
Regards
Logan Page is offline   Reply With Quote
Old   June 29, 2011, 06:56
Default Pipe sinulation.
Marco Bernardes
Many thanks,
Marco.
pipe flow with heat transfer Fabian OpenFOAM 2 December 12, 2009 04:53
How can I increase Heat Transfer at Domain Interf? B.Simon CFX 3 October 28, 2008 18:53
Heat transfer in tube bank. Paul FLUENT 0 August 6, 2004 10:05
Periodical Oscillating flow heat transfer S.L.ZHOU Main CFD Forum 0 September 20, 2000 22:22
