mergeMeshes hex + tet
Old   June 22, 2011, 09:10
Default mergeMeshes hex + tet
flowris is on a distinguished road
I want to do mergeMeshes on a hex and a tet mesh, see picture. Is this possible? When I run
mergeMeshes . grid1 .grid2
I get
Master:      "." "grid1"  region region0
mesh to add: "." "grid2"  region region0
Create Times
Reading master mesh for time = 0
Create mesh
--> FOAM Warning :
    From function directTopoChange::addMesh(const polyMesh&, const labelList&,const labelList&, const labelList&,const labelList&)
    in file directTopoChange/directTopoChange/directTopoChange.C at line 2281
Segmentation fault
flowris is offline   Reply With Quote
Old   June 22, 2011, 09:24
Steven van Haren
stevenvanharen is on a distinguished road
You need to have a conformal interface as far as I know.
This is not the case for you. I don't know how you made the mesh, but maybe you can retry with a conformal interface. I think it will work than.
stevenvanharen is offline   Reply With Quote
Old   June 22, 2011, 15:16
Logan Page
Logan Page is on a distinguished road
You can create nice hybrid structured / unstructured meshes with gmsh (tho it can take a while to setup for more complex geometries). This also imports into OpenFOAM quite nicely.
Logan Page is offline   Reply With Quote
Old   June 23, 2011, 02:45
Arne Stahlmann
Arnoldinho is on a distinguished road
I don't know the source of your error message, but it is generally possible to merge tet + hex meshes and use them in OF, see attached picture. I made this using blockMesh, salome, engrid, mergeMeshes and stitchMesh.
Generally I would not recommend it, as you can get a lot of trouble using tet meshes (at least when using the interFoam solver). You could try snappyHexMesh instead.
Arne
Arnoldinho is offline   Reply With Quote
Old   June 23, 2011, 09:14
kshitij neroorkar
kdneroorkar is on a distinguished road
I know you can have non-conformal interfaces using ggi patches, but I am not sure if it is alright to have one side hex and another side tet. Does anyone know about this?
kdneroorkar is offline   Reply With Quote
Old   June 23, 2011, 10:10
Sandeep Menon
deepsterblue will become famous soon enough
GGI doesn't really care about cell-topology on either side. The only limitation is that patch faces be convex, because of a limitation in the intersection algorithms.
Sandeep Menon
University of Massachusetts Amherst
https://github.com/smenon
deepsterblue is offline   Reply With Quote
Old   June 23, 2011, 10:53
Default A little explanation
Thanks for the many replies.
A little explanation: I made a tet mesh around a foil inside a circle with gmsh. Now I want to add layers on the foil surface. As far as I know, this cannot be done in gmsh, because the foil is an extrude spline profile.
If I use
refineWallLayer -overwrite airfoil 0.3
I get a bad layer with skew cells, see picture.
So any suggestions on how to ad these layers?
Old   June 23, 2011, 11:03
Arne Stahlmann
If you just want to add layers, you might become happy with engrid! On simple structures, I achieved good results with this tool (which is not part of OF!). But it only seems to work for 3D cases - I don't know what your case is.
RefineWallLayers might not be a good choice in your case, as it just splits your surrounding cells.
[blockMesh] Blockmesh error - 2D scramjet ishaninair OpenFOAM Meshing & Mesh Conversion 7 March 18, 2011 00:14
[ICEM] how can i create a consistent transitions between tet and hex? specifically my model? snailstb ANSYS Meshing & Geometry 3 March 15, 2010 20:26
Hex versus Tet Jade M CFX 1 March 11, 2010 23:41
CheckMeshbs errors ivanyao OpenFOAM Running, Solving & CFD 2 March 11, 2009 02:34
poly, hex dom, hex, tet azmir Siemens 0 October 31, 2007 19:24
