Home > Forums > OpenFOAM
OF 2.0.0: Residual control does not work in interFoam
Like Tree5Likes
  • 1 Post By Dr.Faustus
  • 4 Post By wyldckat
Old   June 22, 2011, 11:49
Question OF 2.0.0: Residual control does not work in interFoam
Lars Kiewidt
LarsPT is on a distinguished road
Hi everybody,
I want to use the new convergence check for the PIMPLE solvers in interFoam (OpenFOAM-2.0.0). So, I specified the following in fvSolution:
PIMPLE
    momentumPredictor no;
    nOuterCorrectors 3;
    //nCorrectors     3;
    nNonOrthogonalCorrectors 0;
    nAlphaCorr      1;
    nAlphaSubCycles 2;
    cAlpha          1;
    residualControl
        p_rgh    1e-3;
However, when I run interFoam I get this output at the beginning
PIMPLE: max iterations = 3
    field p_rgh    : relTol 0, tolerance 0
and for each time step
PIMPLE: not converged within 3 iterations
althoug the residual is way under 1e-03!
Is that a bug or am I just missing a switch or something else? I already checked the source files but I could not find any valuable information in there.
Thanks in advance!
Lars
LarsPT is offline   Reply With Quote
Old   June 24, 2011, 17:46
Bruno Santos
wyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nice
Greetings Lars,
Have you also tested it with OpenFOAM 1.7.1 or 1.7.x? If it works with those and not 2.0.0 nor 2.0.x, then you might want to report it as bug!
Best regards,
Bruno
___
I'll be at OFW11 in Portugal
Old   June 28, 2011, 07:25
Lars Kiewidt
According to the OF-2.0.0 Release Notes this is a new feature for all SIMPLE/PIMPLE solvers. It was implementent in simpleFoam in OF-1.7.1 and I tested it successfully, also in OF-2.0.0. However, it is new for interFoam.
Old   August 20, 2011, 08:34
Simon Lapointe
Simon Lapointe is on a distinguished road
Maybe you've already solved your problem, but have you tried something like this:
residualControl
p_rgh
tolerance 1e-3;
absTol 0;
I had the same problem as you described in pimpleFoam and solved it using this syntax.
Simon Lapointe is offline   Reply With Quote
Old   August 20, 2011, 09:03
Lars Kiewidt
Sorry, I didn't work too much on that issue the last weeks. Your hint works perfectly, thank you. I just had to add relTol, so now it looks like this:
residualControl
        p_rgh
            tolerance 1e-06;
            relTol 0;
            absTol 0;
Old   August 6, 2012, 08:53
Alessandro Pani
Dr.Faustus is on a distinguished road
Hi guys! I've tried to modify the commands as suggested by Simon and LarsPT, but this doesn't work for me :
PIMPLE
    momentumPredictor yes;
    nCorrectors     1;
    nAlphaCorr      1;
    nAlphaSubCycles 1;
    cAlpha          1;
    maxCo           0.9;
    maxAlphaCo      0.2;
    nAlphaSweepIter 1;
    rDeltaTSmoothingCoeff 0.1;
    rDeltaTDampingCoeff 1;
    maxDeltaT       1;
residualControl
        p_rgh
            tolerance 1e-02;
            relTol 0;
            absTol 0;
Could you take a look if there's something wrong?
Thanks
Yage likes this.
Dr.Faustus is offline   Reply With Quote
Old   August 7, 2012, 07:28
Bruno Santos
Greetings Alessandro,
A couple of more details would come in handy, such as:
  • What solver are you trying to use? We can assume it's interFoam, but you could be using some other one....
  • What OpenFOAM version are you using?
  • Can this be reproduced in one of OpenFOAM's tutorials? If so, which one?
Best regards,
Bruno
___
Old   August 7, 2012, 08:51
Unhappy
Alessandro Pani
I'm using LTSInterFoam on OF 2.1.1
the test case is the /multiphase/LTSInterFoam/wigleyhull
Old   August 7, 2012, 10:25
Talking Little class on "Know your PIMPLE"
Bruno Santos
OK, let's do a little class on "Know your PIMPLE"
First we look into the file where the "residualControl" is read:
Originally Posted by src/finiteVolume/cfdTools/general/solutionControl/pimpleControl/pimpleControl.C
Foam::pimpleControl::pimpleControl(fvMesh& mesh)
    solutionControl(mesh, "PIMPLE"),
    nCorrPIMPLE_(0),
    nCorrPISO_(0),
    corrPISO_(0),
    turbOnFinalIterOnly_(true),
    converged_(false)
    read();
    if (nCorrPIMPLE_ > 1)
        Info<< nl;
        if (residualControl_.empty())
            Info<< algorithmName_ << ": no residual control data found. "
                << "Calculations will employ " << nCorrPIMPLE_
                << " corrector loops" << nl << endl;
        else
            Info<< algorithmName_ << ": max iterations = " << nCorrPIMPLE_
                << endl;
            forAll(residualControl_, i)
                Info<< "    field " << residualControl_[i].name << token::TAB
                    << ": relTol " << residualControl_[i].relTol
                    << ", tolerance " << residualControl_[i].absTol
                    << nl;
            Info<< endl;
    else
        Info<< nl << algorithmName_ << ": Operating solver in PISO mode" << nl
            << endl;
In bold are the main details to look at. Basically, besides the need for "residualControl", you also need nCorrPIMPLE_, which apparently is "nOuterCorrectors", as you can see in the original post!
Also as you can see, without this value, it will operate in PISO mode! Which the tutorial "multiphase/LTSInterFoam/wigleyHull" uses by default.
There is another example for LTSInterFoam in the latest 2.1.x: https://github.com/OpenFOAM/OpenFOAM...tem/fvSolution
As you can see, neither one use the "nOuterCorrectors", so I do not know if LTSInterFoam is meant to be executed in PISO only or if it can be executed in PIMPLE mode...
Best regards,
Bruno
___
Old   August 27, 2012, 02:49
Alessandro Pani
Hi Wyldckat, sorry for the late reply, but i wasn't able to work on it in past weeks...
I'm taking a look at the controls you've posted... i've added nOuterCorrectors in the fvsolution ( erasing ncorr) and now it runs in PIMPLE and not in Piso... i let you know if the convergence controls works...
But at this steps i would to know if for a problem like the wigley hull is better to run in PISO or in Pimple.... anyway thank you very much for your help... another little piece of the jigsaw puzzle added
Old   October 16, 2012, 02:01
Default Please help me???
  #11
vahid
vahid.najafi is an unknown quantity at this point
Hi dear foamers.
I have a question:
I plot residual for velocity with gnuplot succefully.but have a problem yet!!!
in my controlDict(pic attachmented) deltaT=1e-6 and writeInterval=0.001 , with this options I stop my run and seen 1024 folders in my tutorial.
but I seen in my residual(pic attachmented) ,number of iterations:120000 and we underestand that in my tutorial That have been runed,should be i have 120 folders.????
my Supervisor tell me ,my residual not true???!!!please help me?????
vahid.najafi is offline   Reply With Quote
Thread Tools
Trackbacks are On
icoLagrangianFoam OF1.6 myNewParticleSolver heavy_user OpenFOAM 16 February 11, 2012 06:15
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM 6 April 12, 2011 11:24
TurbFoam problemlarge Co number sunnysun OpenFOAM Running, Solving & CFD 6 March 10, 2009 09:05
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
MRFSimpleFoam amp cyclic patches david OpenFOAM Running, Solving & CFD 36 October 21, 2008 21:55
