OpenFOAM v2.0 and groovyBC
I can't seem to get groovyBC to work with OpenFOAM 2.0. I had it working with 1.7, even though it isn't listed as compatible on http://openfoamwiki.net/index.php/Contrib_groovyBC so I presume it should work with 2.0. Here's what I get after running wmake (not as sudo); touch: cannot touch `Make/linux64GccDPOpt/dontIncludeDeps': Permission denied SOURCE=PatchValueExpressionDriver.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -IMake/linux64GccDPOpt -I/opt/openfoam200/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam200/src/OpenFOAM/lnInclude -I/opt/openfoam200/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/PatchValueExpressionDriver.o In file included from Make/linux64GccDPOpt/location.hh:44, from PatchValueExpressionParser.tab.hh:65, from PatchValueExpressionDriver.H:59, from PatchValueExpressionDriver.C:34: position.hh: In function ‘bool pve::operator==(const pve::position&, const pve::position&)’: position.hh:136: warning: suggest parentheses around ‘&&’ within ‘||’ PatchValueExpressionDriver.C: In member function ‘void Foam::PatchValueExpressionDriver::error(const pve::location&, const std::string&)’: PatchValueExpressionDriver.C:192: error: expected unqualified-id before ‘::’ token PatchValueExpressionDriver.C:192: error: expected ‘;’ before ‘::’ token PatchValueExpressionDriver.C: In member function ‘void Foam::PatchValueExpressionDriver::error(const std::string&)’: PatchValueExpressionDriver.C:202: error: expected unqualified-id before ‘::’ token PatchValueExpressionDriver.C:202: error: expected ‘;’ before ‘::’ token make: *** [Make/linux64GccDPOpt/PatchValueExpressionDriver.o] Error 1 Any suggestions? Thanks. |
I'll have a look at this once I'm back from vacation. If you want to be sure that I remember this and want to be updated on the progress of the port open a ticket at http://sourceforge.net/apps/mantisbt...?page_number=1 Bernhard |
Bernhard PS: Stuff from the other posting still applies |
touch: cannot touch `Make/linux64GccDPOpt/dontIncludeDeps': Permission denied /opt/openfoam200/wmake/scripts/addCompile: 53: cannot create PatchValueExpressionDriver.dep: Permission denied /opt/openfoam200/wmake/scripts/addCompile: 57: cannot create PatchValueExpressionDriver.dep: Permission denied /opt/openfoam200/wmake/scripts/addCompile: 59: cannot create PatchValueExpressionDriver.dep: Permission denied /opt/openfoam200/wmake/scripts/addCompile: 60: cannot create PatchValueExpressionDriver.dep: Permission denied /opt/openfoam200/wmake/scripts/addCompile: 61: cannot create PatchValueExpressionDriver.dep: Permission denied /opt/openfoam200/wmake/scripts/addCompile: 62: cannot create PatchValueExpressionDriver.dep: Permission denied Making dependency list for source file PatchValueExpressionDriver.C make: *** [PatchValueExpressionDriver.dep] Error 2 Since it says permission denied I tried as sudo but then it can't understand wmake. Any suggestions? Thanks. |
Bernhard |
Adam, where did you place the groovyBCs source files?
Mike |
where /~/OpenFOAM is the directory I use to store and execute my cases inside my home folder. |
