buoyantBoussinesqSimpleFoam
hi openfoamers
i have some trouble in using solver buoyantBoussinesqSimpleFoam i got the following error message when i run it: Selecting RAS turbulence model kEpsilon --> FOAM FATAL ERROR: Invalid wall function specification Patch type for patch fixedWalls must be wall Current patch type is patch From function kqRWallFunctionFvPatchField::checkType() in file derivedFvPatchFields/wallFunctions/kqRWallFunctions/kqRWallFunction/kqRWallFunctionFvPatchField.C at line 47. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) in "/opt/OpenFOAM/OpenFOAM-1.7.1/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::error::abort() in "/opt/OpenFOAM/OpenFOAM-1.7.1/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Foam::incompressible::RASModels::kqRWallFunctionFv PatchField<double>::checkType() in "/opt/OpenFOAM/OpenFOAM-1.7.1/lib/linuxGccDPOpt/libincompressibleRASModels.so" #3 Foam::fvPatchField<double>::adddictionaryConstruct orToTable<Foam::incompressible::RASModels::kqRWall FunctionFvPatchField<double> >::New(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/OpenFOAM/OpenFOAM-1.7.1/lib/linuxGccDPOpt/libincompressibleRASModels.so" #4 Foam::fvPatchField<double>::New(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linuxGccDPOpt/buoyantBoussinesqSimpleFoam" #5 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::GeometricB oundaryField(Foam::fvBoundaryMesh const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linuxGccDPOpt/buoyantBoussinesqSimpleFoam" #6 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::readField(Foam::dictionary const&) in "/opt/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linuxGccDPOpt/buoyantBoussinesqSimpleFoam" #7 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::readField(Foam::Istream&) in "/opt/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linuxGccDPOpt/buoyantBoussinesqSimpleFoam" #8 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::fvMesh const&) in "/opt/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linuxGccDPOpt/buoyantBoussinesqSimpleFoam" #9 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::incompressible::autoCreateWallFunctionField< double, Foam::incompressible::RASModels::kqRWallFunctionFv PatchField<double> >(Foam::word const&, Foam::fvMesh const&) in "/opt/OpenFOAM/OpenFOAM-1.7.1/lib/linuxGccDPOpt/libincompressibleRASModels.so" #10 Foam::incompressible::autoCreateK(Foam::word const&, Foam::fvMesh const&) in "/opt/OpenFOAM/OpenFOAM-1.7.1/lib/linuxGccDPOpt/libincompressibleRASModels.so" #11 Foam::incompressible::RASModels::kEpsilon::kEpsilo n(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&) in "/opt/OpenFOAM/OpenFOAM-1.7.1/lib/linuxGccDPOpt/libincompressibleRASModels.so" #12 Foam::incompressible::RASModel::adddictionaryConst ructorToTable<Foam::incompressible::RASModels::kEp silon>::New(Foam::GeometricField<Foam::Vector<doub le>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&) in "/opt/OpenFOAM/OpenFOAM-1.7.1/lib/linuxGccDPOpt/libincompressibleRASModels.so" #13 Foam::incompressible::RASModel::New(Foam::Geometri cField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&) in "/opt/OpenFOAM/OpenFOAM-1.7.1/lib/linuxGccDPOpt/libincompressibleRASModels.so" #14 main in "/opt/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linuxGccDPOpt/buoyantBoussinesqSimpleFoam" #15 __libc_start_main in "/lib/i686/cmov/libc.so.6" #16 Foam::regIOobject::writeObject(Foam::IOstream::str eamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/opt/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linuxGccDPOpt/buoyantBoussinesqSimpleFoam" Abort i probably understand what this message wants to talk to me , but in fact in my blockMesh ,i rly difined the fixedWalls in type of wall without faults and in the folder 0 i also defined all the variable in type wallfunction like this: fixedWalls { type epsilonWallFunction; value uniform 0.00001; } i m appriciate it if someone could help me figure it out ! best |
Hi gaofend,
at least in two of your posted blockMeshDicts you defined your walls as "patch fixedWalls" and not "wall fixedWalls". You can control the definition in "constant/polyMesh/boundary" once again, too. Martin |
Have you taken a look in the constant/polyMesh/boundary -file? Does it say there that the fixedWalls patch is indeed of type wall?
hi martin
thank you , you are right , it works well now ! see you in my next question :) all the best |
hi Joel Lehikoinen
thank you , you are right , i fixed it out in boundary file all the best |
