Why Uprime2mean is minus in some grids?
Like Tree3Likes
  • 1 Post By gregor
  • 1 Post By anon_a
  • 1 Post By gregor
Old   June 30, 2011, 05:14
Question Why Uprime2mean is minus in some grids?
maysmech's Avatar
maysmech is on a distinguished road
Dear Foamers,
I need mean value of u'u', v'v' and w'w' to reach to u' , v' and w'.
when uprime2mean in controlDict switched on these values were written in time folders.
But i don't know why they are minus in some grids.
Any suggestion?
maysmech is offline   Reply With Quote
Old   July 1, 2011, 05:03
maysmech's Avatar
If it is mean of U'U', it should be positive, shouldn't it?
Old   July 1, 2011, 06:45
Gregor Olenik
gregor is on a distinguished road
how can i delete a post ?
gregor is offline   Reply With Quote
Old   July 3, 2011, 07:06
maysmech's Avatar
Any suggestion?
Old   July 6, 2011, 07:56
Vadims Geza
Vadims.geza is on a distinguished road
as I know, uprime2mean is a symmetric tensor, thus with 6 components. cross components (say, U'W') can be negative. check if You are observing right components.
Best Regards
Vadims.geza is offline   Reply With Quote
Old   July 6, 2011, 08:02
maysmech's Avatar
You are right.
its 6 components are: U'U U'V' U'W' V'V' V'W' W'W'
As you say U'W' can be negative but my problem is U'U' is negative in some grids !
Old   January 23, 2012, 19:00
pooyan
sam1364 is on a distinguished road
Hi Maysam,
Did you get any answer from your question?! do you know how uprime2Mean is calculated? I have problem to find out how this parameter is calculated.
Thanks,
Pooyan
sam1364 is offline   Reply With Quote
Old   January 24, 2012, 01:21
Disabled
anon_a is on a distinguished road
Call this a stupid question but I have to ask:
prime2Mean is calculated in src/postProcessing/functionObjects/field/fieldAverage/fieldAverage/fieldAverageTemplates.C
with the following code
scalar alpha = 0.0;
scalar beta = 0.0;
if (faItems_[i].timeBase())
    alpha = (totalTime_[i] - dt)/totalTime_[i];
    beta = dt/totalTime_[i];
else
    alpha = scalar(totalIter_[i] - 1)/scalar(totalIter_[i]);
    beta = 1.0/scalar(totalIter_[i]);
prime2MeanField =
    alpha*prime2MeanField
 + beta*sqr(baseField)
  - sqr(meanField);
Shouldn't the last lines be like this?
prime2MeanField =
  - beta*sqr(meanField);
Or is this just in my head? I never understood...
anon_a is offline   Reply With Quote
Old   January 24, 2012, 07:59
Gregor Olenik
Originally Posted by anon_a View Post
[/CODE]Shouldn't the last lines be like this?
prime2MeanField =
No it shouldn't
they're using the following identy:
1/(n)sum^n(phi_i-<phi>)^2=1/n*sum^n(phi_i^2)-<phi>^2 , where <.> is an averaged value
http://en.wikipedia.org/wiki/Computa...r_the_variance
Edit: added missing 1/n
solefire likes this.
Old   January 24, 2012, 08:57
Disabled
Yes, I am aware of this identity (by the way, you missed 1/(n) in the first sum of the RHS).
However, I have to insist that there is something wrong.
I attach a small pdf with my derivations, can you find the error?
sxpsxp007 likes this.
Old   January 24, 2012, 10:13
Gregor Olenik
i will look through equations when i find some time, in the meanwhile you can have a look at my document.
But i think the problem is that you don't consider the mean value as a "on the fly value" so you can not simply use N<x>^2=(N-1)x^2+x^2 since you need for sigma^2_pr <x>^2_{N-1} instead <x>^2_N
Gregor
PS: And be aware that actually two steps are performed
1. removing the old mean value in addMeanSqrToPrime2Mean<scalar, scalar> in fieldAverage.C Line 175
2. evaluating the variance using current mean value calculatePrime2MeanFields<scalar, scalar> in fieldAverage.C Line192
Old   January 24, 2012, 11:20
Disabled
Sorry but there seem to be many errors in your derivations:
- In your calculations, you take (1) (which, I assume, is your interpretation of the OF expression) as correct, while I am trying to see if it can be proven.
- Where did the term <phi>_{i-1}^2 in (1) come from? It does not exist in OF.
- The substitution in (2) was performed incorrectly, terms like (n-1)/n and <phi>_{i-2}^2 are missing in the parenthesis.
- Where did sigma_{i-2} go in (3)?
- Where did the sum come up in (4)?
and so on...
EDIT: I now see your point about the existence of <phi>_{i-1}^2 after your note about addMeanSqrToPrime2Mean.
To be honest, this confuses me even more.
Old   January 24, 2012, 11:41
Gregor Olenik
So do it the other way round and look if can derive it from the algorithm
look what happens in the addMeanSqrToPrime2Mean function.
sigma_{i-1} = sigma_{i-2} + <phi>^2_{i-1}
thats the step performed in addMeanSqrToPrime2Mean in fieldAverageTemplates.C line 264
prime2MeanField += sqr(meanField);
like if have written i assume it to be zero (which might not be true for i-2 but has to be for i=0 and since all the old mean values are canceled out for every timestep it should be ok)
you could write (3) as
sigma = alpha * phi^2_old + beta*phi^2 - <phi>_i^2
which is
sigma = <phi^2>_i - <phi>_i^2
or
sigma = 1/n sum(phi_i^2) - <phi>_i^2 .
I know its not nice and there are many typos but may be you still see the point
Gregor
Old   January 24, 2012, 11:56
Gregor Olenik
You could try it by evaluting it manually. The point is you want to have a variance every time step but your final mean value is unknown, therefore you take the current mean value. But once you use the current mean value the old mean values has to be taken out.
Old   January 24, 2012, 12:25
Disabled
Well, I thought about it on the way home.
It's quite simple now that you told me about addMeanSqr.
You can add and substract (N-2)/(N-1) (<x>)^2 in my last equation and the OF expression is obtained.
Thanks for your help, patience and time, it is clear now!
I assume that this square is added in the beginning to avoid numerical errors, cancellations of significant digits and so on, right?
Old   January 24, 2012, 12:36
Gregor Olenik
Yes i guess it is the same reason why you calculate the average by
<phi> = alpha*<phi>_{i-1} + beta * phi
instead of using
phiS += phi
phiA = phi/N
to avoid big numbers.
Sorry if wasn't that clear. Explaining something easy is an art
Old   August 9, 2012, 23:52
aka
Getnet
aka is on a distinguished road
Hi Gregor,
You said "The point is you want to have a variance every time step but your final mean value is unknown, therefore you take the current mean value." I understand most of your derivations however, I am still confused on the idea of using the "current mean value" instead of the "final mean value". For the variance, we need the final mean value and using the current mean value may have a significant effect for strongly separated flows. I also see a difference on the last term of your derivation on the "test.pdf" file. You used <phi>_i^2 on the last term in equation (2) however <phi>^2 is coming on your equation (3). It seems you are going from the current mean to the final mean value. I appreciate your help on this part. It took me some time to get convinced with the way "prim2Mean" is calculated in OpenFOAM.
Thanks a lot!
aka is offline   Reply With Quote
Old   August 13, 2012, 04:45
Gregor Olenik
In step 1 in the pdf file you plug in the old variance and the old mean value gets cancelled out. This means you are alway using the current mean value. The current mean value is correct but only up to the current (i-th) time step. In the next time step you update the mean value, take out the effect of the old (which is not valid anymore) value and calculate the variance using the new current mean value. However on the long run your mean value should converge and therefore shouldnt change anymore, because if your mean value is not converged there is no chance that your variances are converged.
I agree that the document is very sloppy written. The point is, that your current mean value is the final value for your time series up to time i.
Old   August 22, 2012, 03:33
aka
Getnet
Thanks Gregor . I appreciate it.
Old   November 14, 2012, 07:31
Aru
arunsmec is on a distinguished road
UPrime2mean has 6 components 0,1,2...5. Among these which are <uu>, <v v> and <ww>?
arunsmec is offline   Reply With Quote
Time step at coarse grids D3sT Main CFD Forum 0 December 6, 2010 11:15
A question about dynamic overset grids JXIA Main CFD Forum 4 January 10, 2008 03:50
Reloading grids in Pre Pascale Fonteijn CFX 1 July 7, 2003 13:33
Minus Volume of cells di bonga CFX 2 April 8, 2001 13:38
UDF Face Fluxes & Partitioned Grids Greg Perkins FLUENT 0 April 6, 2001 01:50
