-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   Polynomial thermophysical properties and laminar porous Zone (http://www.cfd-online.com/Forums/openfoam/90097-polynomial-thermophysical-properties-laminar-porous-zone.html)
vemps June 30, 2011 10:13
  • I am solving a simple exhaust system problem with porous domain. Want to avoid commercial Fluent software for simple problems.
  • Initially i solved the Problem using constant Cp value with sutherland viscosity. My pressure drop in the system slightly varies between OpenFoam rhoPorousMRFSimpleFoam and Fluent.
  • Fluent use Cp Polynomial varying with T, thermal conductivity polynomial varying with T, Laminar porous Zone, k and epsilon with intensity and hydraulic diameter.
  • I want to invoke similar criteria for the above parameters in Open Foam to get close match in pressure drop.
  • Can somebody please help me to give a detailed explanation or links as i am new to OpenFoam
  • How to give Cp and thermal conductivity polynomial ( i have gone through the modification of thermoType in one of the thread hPsiThermo<pureMixture<sutherlandTransport<specieT hermo<hPolynomialThermo<perfectGas>>>>>
  • Can somebody help me to give the details
  • How to give laminar Porous zone
  • What is the equivalent model in OpenFoam for k&epsilon of Fluent Intensity and hydraulic diameter. At present i am using k &epsilon of default properties specified in tutorial angledDuctImplicit
