Mesh check fail
Hi all,
Currently running trials for solidworks -> pointwise -> openfoam -> paraview process of simulations. I have created my model in solidworks, then created a hybrid mesh with openfoam boundaries in pointwise. When i import and execute checkMesh in terminal i get the following... ***Boundary openness (-1.25496e-08 0.00676147 1.33344e-05) possible hole in boundary description. ***Open cells found, max cell openness: 1, number of open cells 69988 <<Writing 69988 non closed cells to set nonClosedCells Failed 2 mesh checks. Anyone elese had similar issues or used the same program processes that i am trying to achieve? Any help would be welcomed. Regards John |
eddiejohn,
What version of Pointwise are you using (Help > About Pointwise)? There was a problem with the orientation of prism blocks getting reversed when exported to OpenFOAM - and thus causing the error you're seeing - but that was fixed relatively recently. If possible, it would also be helpful to see an image of what your mesh (in Pointwise) looks like. -Chris |
1 Attachment(s)
Chris,
Thankyou for your reply. I am running the following version; Pointwise V16.04 Release 3 -- Optimized Build 0138141200 Windows 64-bit. Its a 30 day trial. Please find attatched a jpeg of the mesh in pointwise. Tried just ignoring the error and running OpenFoam but to no avail. Any ideas? Thanks John |
Who are you currently evaluating for/with? Your mesh looks fine in the picture but you might have to send it to me to look at it closer. Let me know if you are able to - send me an email.
checkMesh fail
hello everybody,
I'm using the rhoCentral Foam (2.0 version) and I have been problems to generate my mesh. My mesh is composed by two regions, the first one is rectangular and the second one is a parallelepiped. For the region when I run the commands blockMesh and checkMesh everything is ok, but when I introduce the second region the openFoam give the following error: "number of edges not aligned or perpendicular to non-empty directions". I substituted the parallelepiped region for other rectangular region and everything works fine. Maybe the openFoam don't accept angles in the mesh ? Somebody could help me ? Thanks |
Maybe you are allready aware of this, so maybe an irrelevant answer. As far as I know solid works draws the hardware (pipe wall), where openfoam needs a mesh of the fluid (inside of pipe). so you need to subtract the hardware from the enclosing fluid and mesh this. hope this helps Wouter |
mesh issue
Hi foamers !
I've an issue with my mesh generated with blockMesh and snappyHexMesh (OpenFoam V1.7) with a geometry given by a .obj file. I work in 2D, but the mesh present some errors and I can't find why ! Can sb help me ?? I think that errors come from some edges that pass through several cells and even through the foil ! I put a picture of my mesh and my snappyHexMeshDict file down below ! Thanks in advance! /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.7.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object snappyHexMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Which of the steps to run castellatedMesh true; snap true; addLayers true; geometry { wing_NACA66.obj { type triSurfaceMesh; } refinementBox { type searchableBox; min (-0.5 -0.5 -1); max ( 2 0.5 1); } }; // Settings for the castellatedMesh generation. castellatedMeshControls { maxLocalCells 1000000; maxGlobalCells 2000000; minimumRefine minRefinementCells 100; nCellsBetweenLevels 6; features (); refinementSurfaces { wing_NACA66.obj { level (4 4); } } resolveFeatureAngle 30; refinementRegions { //refinementBox //{ // mode inside; // levels ((1e15 3)); //} wing_NACA66.obj { mode distance; levels ((0.15 4) (0.3 3) (0.4 2)); } } locationInMesh (-0.5 0 0); allowFreeStandingZoneFaces true; } snapControls { nSmoothPatch 3; tolerance 4.0; nSolveIter 30; nRelaxIter 5; } addLayersControls { relativeSizes false; layers { "wing.*" { nSurfaceLayers 3; } } expansionRatio 1.2; finalLayerThickness 0.002; minThickness 0.0002; nGrow 0; // Advanced settings featureAngle 60; nRelaxIter 5; nSmoothSurfaceNormals 1; nSmoothNormals 3; nSmoothThickness 10; maxFaceThicknessRatio 0.5; maxThicknessToMedialRatio 0.3; minMedianAxisAngle 90; nBufferCellsNoExtrude 0; nLayerIter 50; } meshQualityControls { maxNonOrtho 65; maxBoundarySkewness 20; maxInternalSkewness 4; maxConcave 80; minVol 1e-13; minTetVol 1e-20; minArea -1; minTwist 0.05; //- minimum normalised cell determinant minDeterminant 0.001; minFaceWeight 0.05; minVolRatio 0.01; minTriangleTwist -1; nSmoothScale 4; errorReduction 0.75; } debug 0; mergeTolerance 1E-6; // ************************************************** *********************** // [IMG]file:///mnt/home/stagiaires/marie-alix.lorin/Desktop/Capture.png[/IMG] |
1 Attachment(s)
and the picture !
