Solving System of Linear equations
Old   September 29, 2009, 08:33
Default Solving System of Linear equations
Mihails Ščepanskis
shchepan is on a distinguished road
Hi!
I need to solve in OpenFOAM system of linear equation like
A*b = c
where A is tensor (rank 2) and c is vector. A and c are constants.
How can I solve this equation?
Thank you
shchepan is offline   Reply With Quote
Old   September 30, 2009, 01:03
Mihails Ščepanskis
Thank you, Stanley!
Can you show how to use this function?
What H-file I should include solve function to work?
Old   October 1, 2009, 00:09
Mihails Ščepanskis
//I've created tensor A:
tensor A(Axx, Axy, Axz, Ayx, Ayy, Ayz, Azx, Azy, Azz);
//and vector c:
vector c(cx, cy, cz);
and now I want to get vector b: A*b=c
Old   October 1, 2009, 19:05
akidess's Avatar
Anton Kidess
Why use OpenFOAM instead of MATLAB / Octave for this?
Old   October 2, 2009, 00:46
Mihails Ščepanskis
Anton, because it is only one step of big programm.
First I solve MHD turbulent equations in crucible. Then I solve lagrangian equation for solid particle motion. I take into acount lift force to (proportional U x rot(U)). And to solve this aquation I need to solve system of linear algebraic equations.
Old   November 14, 2010, 13:03
Niklas Winkler
nikwin is on a distinguished road
Hi Mihails,
I would also be able to solve a system of linear equations in OF as a part of a larger code. Did you ever find out if there is a possibility to solve a system of linear equations i OF?
Thanks
nikwin is offline   Reply With Quote
Old   November 14, 2010, 15:04
Lukasz Miroslaw
Lukasz is on a distinguished road
Send a message via Skype™ to Lukasz
Why don't you use our GPU-baed code (speedit.vratis.com)? It can be easily plugged to OF. So far we support CG/BiCGSTAB for solving symmetric/unsymmetric matrices in single/double precision (soon also with complex values).
Lukasz is offline   Reply With Quote
Old   November 15, 2010, 02:50
Mihails Ščepanskis
Year ago I decided that it is much easier for me to write my own code that solve systems of linear equation using Gauss method.
Mihails Ščepanskis
Laboratory for Mathematical Modelling of Environmental and Technological Processes
University of Latvia
Old   November 15, 2010, 04:30
Lukasz Miroslaw
But happens if the matrix is huge and sparse. The memory requirements are quite high for Gauss method.
Old   November 15, 2010, 04:40
Mihails Ščepanskis
Of course you are right, Lukasz. I am solving my specific problem and I have no goal to write universal code for systems of linear equations.
Mihails Ščepanskis
Old   November 16, 2010, 04:27
Niklas Winkler
Thanks both of you!
The simplest way for me is to go for Michails suggestion, which I've already implemented in Matlab. Now I will just need to rewrite it into OF which for me will be the tricky part.
Regards
Old   November 16, 2010, 04:36
Stefan Herbert
herbert is on a distinguished road
if you want to use Gauss-algorithm only, you don't have to hardcode it. There is already a class called simpleMatrix which can do this job. The source is located in src/OpenFOAM/matrices/simpleMatrix/ .
I don't know if there is an example in any solver, but it is quite simple to use.
Regards,
Stefan
herbert is offline   Reply With Quote
Old   November 16, 2010, 06:52
Niklas Winkler
Perfect!
It works as expected.
Thanks
/NW
Old   December 5, 2013, 10:40
Evangelos
Danath is on a distinguished road
Hello ! can you tell me how you add simpleMatrix to your code ?
I am trying to do the same thing but i have a lot of problems !
Danath is offline   Reply With Quote
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
