question about chemkinToFoam
Old   July 14, 2011, 20:58
Default question about chemkinToFoam
Sunny Karnani
skarnani is on a distinguished road
Hi.
I recently upgraded to OpenFOAM 2.0 and I've run in to a small issue using the chemkinToFoam utility. Instead of getting something that looks like
OH
specie
nMoles 1;
molWeight 17.0074;
thermodynamics
Tlow 200;
Thigh 3500;
Tcommon 1000;
highCpCoeffs ( 3.09289 0.00054843 1.26505e-07 -8.79462e-11 1.17412e-14 3858.66 4.4767 );
lowCpCoeffs ( 3.99202 -0.00240132 4.61794e-06 -3.88113e-09 1.36411e-12 3615.08 -0.103925 );
transport
As 1.67212e-06;
Ts 170.672;
I get something like the following:
CN
nMoles 1;
molWeight 26.0179;
Tlow 200;
Thigh 6000;
Tcommon 1000;
highCpCoeffs ( 3.74598 4.34508e-05 2.9706e-07 -6.86518e-11 4.41342e-15 51536.2 2.78676 );
lowCpCoeffs ( 3.61294 -0.000955513 2.1443e-06 -3.15163e-10 -4.64304e-13 51708.3 3.9805 );
As 1.67212e-06;
Ts 170.672;
Without those tags before each grouping, I get an error that reads,
Selecting psiChemistryModel ODEChemistryModel<gasThermoPhysics>
Selecting thermodynamics package hsPsiMixtureThermo<reactingMixture<gasThermoPhysic s>>
Selecting chemistryReader foamChemistryReader
--> FOAM Warning :
From function entry::getKeyword(keyType&, Istream&)
in file db/dictionary/entry/entryIO.C at line 77
Reading /home/sunny/OpenFOAM/sunny-2.0.0/run/tutorials/combustion/reactingFoam/ras/counterFlowFlame2D/chemistry/test2
found on line 25 the punctuation token '{'
expected either } or EOF
--> FOAM FATAL IO ERROR:
keyword specie is undefined in dictionary "/home/sunny/OpenFOAM/sunny-2.0.0/run/tutorials/combustion/reactingFoam/ras/counterFlowFlame2D/chemistry/test2::CN"
file: /home/sunny/OpenFOAM/sunny-2.0.0/run/tutorials/combustion/reactingFoam/ras/counterFlowFlame2D/chemistry/test2::CN
From function dictionary::subDict(const word& keyword) const
in file db/dictionary/dictionary.C at line 461.
FOAM exiting
I can't be sure, but I imagine this is a straightforward fix. The problem is, I don't know where to begin.
Any suggestions?
Thanks.
Sunny
skarnani is offline   Reply With Quote
Old   July 15, 2011, 04:14
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
Interesting, I also have an issue with reading the thermo file, with an error
--> FOAM FATAL ERROR:
while reading thermodynamic data specie formula on line 2
expected <word><label><word><label><word><label><word><labe l> (4(2A1,I3)) but found '"."00'
From function chemkinReader::lex()
in file chemistryReaders/chemkinReader/chemkinLexer.L at line 1497.
If you post up your chem.inp and therm.dat files I can take a look.
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
Old   July 15, 2011, 12:40
Sunny Karnani
Thanks for your willingness to assist. I attached three files:
1 & 2 are the original CHEMKIN mechanism and thermo file. The third file is the FOAM converted thermo file. You will notice in the FOAM thermo file that the first specie -- OH -- has the required tags that I mentioned in the previous post. I had put those in to test if that was the source of the error.
BTW, which version of OpenFOAM and solver are you using? Your error looks like a similar issue, but the output is different.
Thanks again.
Sunny
Old   July 15, 2011, 12:48
I've posted a bug report:
http://www.openfoam.com/mantisbt/view.php?id=251
Keep track of that and I'm sure it will be fixed reasonably soon.
Old   July 20, 2011, 04:12
This has been fixed in OF-2.0.x:
https://github.com/OpenCFD/OpenFOAM-...716d3ed0dcef41
Old   July 20, 2011, 12:20
Sunny Karnani
Very cool. Thanks for the update.
Old   September 2, 2011, 17:39
Default error message after changes made
Ryan Johnson
RyanJohnson is on a distinguished road
I get this error message after running chemkinToFoam
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/rfj2c/OF/OpenFOAM-2.0.x/platforms/linux64Gcc45DPOpt/lib/libOpenFOAM.so"
#1 Foam::sigSegv::sigHandler(int) in "/home/rfj2c/OF/OpenFOAM-2.0.x/platforms/linux64Gcc45DPOpt/lib/libOpenFOAM.so"
#2 __restore_rt at sigaction.c:0
Segmentation fault
after making the changes to the code I recompiled using ./Allwmake in the /src/ directory
thanks in advance!
RyanJohnson is offline   Reply With Quote
Old   September 3, 2011, 04:49
What changes to the code did you make? What input files are you running chemkinToFoam on? Where did it fail? You need to give more information.
Old   September 5, 2011, 16:59
Default Problems with ChemToFoam
Ryan Johnson
I changed files by doing the bug fixes exactly as the link above isntructed to do (changed the 10 files as listed above)
I then recompiled the entire directory in the /src/ to make sure that any refrences to these headers would be recompiled.
I then tried again to run the chemkinToFoam and get the segmentation fault error exactly as shown above. I use chemkinToFoam on the attached files.
ChemkinToFoam worked with these two files in the OpenFoam 1.7 release that I am currently using.
Thanks for your help, and sorry about the brevity earlier,
Ryan
##EDIT##
I was able to get it to work when I did ./Allwmake for the entire OpenFOAM environment, some clarification on why this would be needed and not just needed in the /src/ directory would be quite imformative
thanks for your help again!
Old   September 6, 2011, 04:01
Hmm, you'll probably find you only needed to recompile applications/utilities/thermophysical/chemkinToFoam. Did you change anything else in between the above? Glad to hear it worked in any case.
Old   November 30, 2011, 06:22
Arrow
  #11
Ayhan Eses
ayhan515 is on a distinguished road
Dear Foamers,
Firstly, i ran chemFoam at /home/ayhan/OpenFOAM/ayhan-2.0.1/run/tutorials/combustion/chemFoam/gri case
It works without fail.
And it draws graph. ok.
Then i used
chemkinToFoam chem.inp therm.dat reactions thermo
command and i put reactions and thermo files to constant folder.
And i changed to thermophysicalProperties file.
|  \\    /   O peration     | Version:  2.0.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      thermophysicalProperties;
thermoType      hsPsiMixtureThermo<reactingMixture<gasThermoPhysics>>;
//inertSpecie N2;
chemistryReader foamChemistryReader;
foamChemistryFile "$FOAM_CASE/constant/reactions";
foamChemistryThermoFile "$FOAM_CASE/constant/thermo";
Then i use ./Allrun command
And it draws graph. but..
this time got that picture.
Is there something wrong arrangement? How can i fix that?
and h2 case
without modification
chemkinToFoam & foamChemistryReader
ayhan515 is offline   Reply With Quote
Old   September 11, 2013, 08:07
Default help regarding reactionFoam solver .
  #12
sonu
yash.aesi is on a distinguished road
greeting oll ,
i am relatively new to OF. nowadays i am trying to simulate my case of different species with the reactingFoam solver and m using openFoam 2.2-x . fist i solved the tutorial of counterFlow Flame after that nw i tried to run my case . but in starting one thing which is paining me is what to write in in thermophysical properties file . shown below :
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
thermoType
    type            hePsiThermo;
    mixture         reactingMixture;
    transport       sutherland;
    thermo          janaf;
    energy          sensibleEnthalpy;
    equationOfState perfectGas;
    specie          specie;
inertSpecie N2;
foamChemistryThermoFile "$FOAM_CASE/constant/thermo.compressibleGas";
reaction and thermo.compressible file is there in constant folder of my case .
so can anybody guide me what should i change in the above file marked bold ?
thanks in advance ,
Regards ,
sonu
File Type: zip reactions.zip (322 Bytes, 22 views)
yash.aesi is offline   Reply With Quote
question about uds tanven FLUENT 2 July 5, 2015 11:22
Unanswered question niklas OpenFOAM 2 July 31, 2013 16:03
Poisson Solver question Suresh Main CFD Forum 3 August 12, 2005 04:37
CHANNEL FLOW: a question and a request Carlos Main CFD Forum 4 August 23, 2002 05:55
question K.L.Huang Siemens 1 March 29, 2000 04:57
