make Box by use of surrounding faces
Dear users,
I am quite new with OF but I will try to follow your kindly advices. My problem is as follows: I want to simulate a bearing chamber consisting of a rotor (inner face) and with a liquid (alpha = 1) volume(!)layer at the stator (outer face). I was adviced to have a look at the damBreak tutorial. As I imported a mesh from Ansys Icem, I canīt really relate to the original boxtoCell entry in system/setFieldsDict. My imagination of solving the problem is to create a volumebox by the use of four enclosing faces and to set this "field" to "value alpha = 1" as an initial value. My question is how to do so and how to bring in "setSet, faceSet, boxToFace etc.". Which of them do I need and what do they do?? Thank you in advance for some helpful posts or links! Cheers, Mike. |
Hi Mike,
The answer is right! The boxToCell will assign a value of alpha = 1 for the problem domain (i.e. all cells) that can be found inside a box that you specify with the coordinates of two points. If the outer shape of the volume, for which alpha =1, is not composed of rectangles or domain boundaries, then you should consider a zoneToCell approach or funkySetFields. Regards Hisham |
