January 27, 2017, 05:29 |
Lower calculation in parallel than in serial
Jean bon
Rep Power: 9 |
Hi everybody,
I have a strange problem. I have a case with about 300K cells. I am trying to run it in parallel. It works but it is lower than with only one core. I have looking for solution in this forum but there is nothing. I run it on a cluster SGI UV 2000. The processors are Sandy Bridge E5-4640 @ 2.40GHz. Even with 2 processors, it is lower (the executation time and the clock time): 1 processor with 4gb is faster than 2 with 4gb. The problem does not come from the communication between the processors (I think) because even the execution time is bigger. I tried to run other cases with less cells or more cells, and it is always the same result. I also tried to run these cases on my computer, not the cluster, and parallel performance are better than serial performance with one core. I modified the solvers, the decomposition method but even if it can improve the time of calculation, it is still lower. If someone has an idea, I would be grateful. |
February 1, 2017, 09:23 |
Jean bon
Rep Power: 9 |
No idea ?
February 1, 2017, 21:07 |
khedar
Rep Power: 9 |
How did you check the communication times? And what did you change in the solver to make it slightly faster?
Display Modes | |
parallel run is slower than serial run (pimpleFoam) !!! | mechy | OpenFOAM | 18 | August 17, 2016 17:19 |
Dynamic mesh adaption in parallel calculation | xh110120 | FLUENT | 1 | March 12, 2016 08:05 |
Parallel vs Serial Run-Solver manager | rohit_turbo | CFX | 5 | March 4, 2016 08:34 |
Dynamic mesh crashes in parallel, but works in serial | 86lolo | FLUENT | 7 | June 24, 2014 05:24 |
Parallel run diverges, serial does not | SammyB | OpenFOAM Running, Solving & CFD | 1 | May 10, 2009 03:28 |
