-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   Viewing multiregion results (http://www.cfd-online.com/Forums/openfoam/91014-viewing-multiregion-results.html)
mirko July 27, 2011 19:52
I am running OF2.0.
When I run a multi-region tutorial, such as multiRegionHeater, I cannot view calculated values in ParaView 3.10.1
When I select time-step 0, I can see the list of calculated fields in paraview's Volume Fields window.
When I select other time-steps, the Volume Fields becomes zero, and I cannot view any other fields (pressure, temperature, velocity).
Any idea what could be wrong?
Thank you,
Mirko
joel.lehikoinen July 28, 2011 07:48
In the case dir, run
foamToVTK -region <region_name>
for each region. That converts the FOAM data to VTK format and places them in a folder called VTK. Inside that folder you'll find subfolders for each region, and within them, a file you can open in Paraview.
mirko July 29, 2011 15:04
Thanks, that works.
Mirko
sparbroetchen September 21, 2011 06:02
multiRegion post processing
A much easier way ist the following:
open Paraview by typing
paraFoam -region region1
Then generate a wrapping File for the second region
touch caseName{region2}.openFoam
This file must be opened with paraview and the region2 will appear.
Greetings
Sebastian
