Home > Forums > OpenFOAM
How to create a free surface application in Openfoam ?
Like Tree2Likes
Old   September 12, 2011, 10:19
Kent Wardle
kwardle is on a distinguished road
In your test case, have you made the top surface a wall or a constant pressure outlet patch? Sounds like that is what you want. That will help keep the 'outlet' behaving physically.
kwardle is offline   Reply With Quote
Old   September 12, 2011, 10:35
Mohammad Fereshtehpour
MOHAMMAD67 is on a distinguished road
Send a message via Skype™ to MOHAMMAD67
Hi Nima
I've changed the type of outlet pressure to buoyantPressure but the following error obtained:
--> FOAM FATAL ERROR:
Continuity error cannot be removed by adjusting the outflow.
Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow.
Total flux : 1e-300
Specified mass inflow : 1.27e-05
Specified mass outflow : 0
Adjustable mass outflow : 0
From function adjustPhi(surfaceScalarField& phi, const volVectorField& U,const volScalarField& p
in file cfdTools/general/adjustPhi/adjustPhi.C at line 115.
FOAM exiting
I try to implement groovybc and tell you the result.
MOHAMMAD67 is offline   Reply With Quote
Old   September 12, 2011, 13:47
Default Outlet Pressure
  #23
Hi Kwardle,
What do u mean exactly by constant pressure outlet patch. could u please check my file for this case? I don't know how to consider constant pressure above the surafce and hydrostatic pressure below the surface.
Old   September 13, 2011, 14:23
Kent Wardle
Mohammad,
I took at your 0 BCs. You have a boundary in p_rgh called atmosphere which is not used. Anyway, your outlet patch is not set up correctly. You will want to use inletOutlet for alpha1, totalPressure for p_rgh and pressureInletOutletVelocity for U on your outlet patch. If you had not set up the inlet as you have done with a partial patch of alpha1, I think in order to get this to solve and not blow up you would have also had to make the upperWall an 'outlet' boundary with all the same BC types as your named outlet patch. Attached is a 0 directory with the changes that work for me.
Here is an animation through 1s.
Please take a close look through the BCs and make sure it is clear what I have changed so you can do it yourself in the future. Hope this helps!
-Kent
Old   September 14, 2011, 14:28
Default new case
  #25
Hi Kwardle,
Thanks a lot for your attention. I did what you said and the results obtained was the same as yours. In order to model my case, I built a model and implement the required changes. It's result is a little strange. I reallly couldn't explain what happen.
Here is my file:
http://www.4shared.com/file/4k8mRux_/D13T.html
Thanksgod, You really made me hopefull for learning openFoam better.
Old   September 14, 2011, 14:32
Kent Wardle
Please post the file here directly. I cannot get the file from your link.
Old   September 14, 2011, 14:46
Default flow on step new case
  #27
really thanks Kwardle, Mesh file is bigger than the uploading limit. what shoul I do? could u please give me your email.
Old   September 14, 2011, 14:51
Kent Wardle
Is it generated from blockMesh? If so, just upload the blockMeshDict only without the mesh.
-Kent
Old   September 21, 2011, 03:35
Jindo
phuchuynh is on a distinguished road
Hi Mohammad !
Can u upload file or post your solver on forum ? This is best reference.
thanks
phuc
phuchuynh is offline   Reply With Quote
Thread Tools
Trackbacks are On
Free Surface Ship Flow timfranke OpenFOAM Running, Solving & CFD 307 March 19, 2016 22:26
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
free surface around a ship hull Stephy OpenFOAM Running, Solving & CFD 12 April 24, 2012 01:12
Porous media in free surface application chiggins OpenFOAM Running, Solving & CFD 0 July 3, 2008 11:25
Modeling Free Surface Flows Elliot Schwartz Main CFD Forum 5 August 25, 1998 21:03
