July 28, 2011, 13:20 |
How to Determine Patch Size
Matthew Denno
Rep Power: 16 |
Does anyone know how to determine the size of a patch (in say square meters)? I used snappyHexMesh to generate a mesh that conforms to an irregular surface and now I am trying to determine the inlet boundary patch size.
Thanks, MD |
July 28, 2011, 13:57 |
Philip Cardiff
Rep Power: 34 |
If you use the "patchIntegrate" utility, it will tell you the area of a patch. patchIntegrate takes two arguments, the first is the volScalarField you wish to integrate, and the second is the patch you want to integrate over. In your case just specify any volScalarField you have. It will print out the patch area as well as the integrated value. Hope it helps, Philip |
July 28, 2011, 16:06 |
Matthew Denno
Rep Power: 16 |
Phil,
Thanks for your help. I don't have my boundaries set up yet for this project so I don't have any scaler fields yet either...I will do as you suggested as soon as I get to that point. Thanks again, MD |
July 28, 2011, 16:14 |
Rep Power: 16 |
July 30, 2011, 12:52 |
Matthew Denno
Rep Power: 16 |
Phil and doubtsincfd thank you for your suggestions.
Phil I did as you suggested and it worked - thanks. doubtsincfd I took a look at the link you suggested. It looked like a good solution, but maybe a little above my ability in OF at the moment as I haven't tried to do any coding with OF yet. Planning to try soon. |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
