how to refine mesh imported from fluent?
Dear all,
I have a mesh imported from fluent using fluentMeshToFoam, and I need to refine it. I tried refinemesh, but it doesn't work, always giving me the warning --> FOAM Warning : From function Foam::cellCuts::edgeEdgeToFace(const label cellI, const label edgeA,const label edgeB) const in file meshCut/cellCuts/cellCuts.C at line 257 cellCuts : Cannot find face on cell 394530 that has both edges 643914 1844370 faces : 4(1149145 3790120 466179 1030300) edgeA : (96986 230263) edgeB : (275544 518188) Marking the loop across this cell as invalid Killed I am a newbie to OpenFOAM. I am not sure whether there is something wrong with my imported mesh, or I used 'refinemesh' the wrong way. Can anyone give me some tips or suggestions? Thank you so much! Best, Hang |
Hi Hang,
Did you ever resolve this issue? I am having the same "problem". refineMesh is not failing (still running) but I am getting that same warning. Not sure if it is a problem though. Thanks, MD |
Hi Matthew,
Sorry for the detailed reply. Have you got any results yet? I didn't get refineMesh work, and then switched to enGrid, which is another open source package. Here is a link to a tutorial: http://engits.eu/wiki/index.php/Tuto...der_and_enGrid It might be helpful to you. Best, Hang |
