-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   OpenFoam to Fluent data conversion Problem (http://www.cfd-online.com/Forums/openfoam/91220-openfoam-fluent-data-conversion-problem.html)
vemps August 4, 2011 01:08
4 Attachment(s)
I am working with simple pipe flow with porous domain and the wall of the porous zone is considered as slip wall. After solving i saw there are differences when viewing the results in Paraview and data converting to Fluent and viewing the results in Fluent.
1. At the inlet i saw there are differences in velocity magnitude and pattern of contours.
2. At the midplane which cuts the slip wall, paraview showing the velocity magnitude without zero velocities at wall ( outer boundary). But Fluent after transferring the data shows zero velocity at the wall for mid plane.
Please help me where i made a mistake in transfering the data.
I am using following file for converting the openfoam data to Fluent
| \\ / O peration | Version: 2.0.0 |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | | \*---------------------------------------------------------------------------*/
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object foamDataToFluentDict;
p 1;
U 2;
T 3;
h 4;
k 5;
epsilon 6;
gamma 150;
vemps August 8, 2011 02:30
Problem with Fluent data conversion
Hello Users,
Please help me where i wet wrong in converting the OpenFoam data file to Fluent format.
Regards
Krishna
