Home > Forums > OpenFOAM
Boundary conditions for the bifurcated arteries.
Old   August 10, 2011, 07:11
Default Boundary conditions for the bifurcated arteries.
Guifan Li
liguifan is on a distinguished road
Hi OpenFoamers:
What I am doing is to repeat an experiment from a journal. It is a bifurcation with one inlet and two outlets.
My boundary condition is following:
p
inlet: zeroGradient
outlet1: zeroGradient
outlet2: fixedValue ( Value uniform 0 ) ( I think this is "zero reference pressure" )
U
inlet: parabolic steady velocity
outlet1: zeroGradient ( fully developed )
outlet2: zeroGradient ( fully developed )
I use these boundary conditions from a journal. But the results is wired.
The blood only pass through outlet2 which "zero reference pressure present". It never pass through the other vessel.
Can someone point out errors for me?
Thanks a lot!
liguifan is offline   Reply With Quote
Old   June 26, 2013, 13:46
India
mayank.dce2k7 is on a distinguished road
I am also doing the same problem. Single tube bifurcating in two.
The problem in your boundary condition is with pressure. I used following condition for pressure at following outlet and got the fluid(in my case air) from both the outlets:
OUTLET
type fixedValue;
value uniform 0;
How did you set up your case? Can u share the case file? How did u manage to apply parabolic profile at the inlet?
Regards,
Mayank.
mayank.dce2k7 is offline   Reply With Quote
Thread Tools
Trackbacks are On
symmetry boundary conditions in cfx lost.identity CFX 41 May 22, 2013 07:21
Impinging Jet Boundary Conditions Anindya Main CFD Forum 24 January 11, 2012 14:40
OpenFOAM Variable Velocity Boundary Conditions NickolasPl OpenFOAM Programming & Development 2 May 19, 2011 05:37
boundary conditions and mesh exporting vaina74 Open Source Meshers: Gmsh, Netgen, CGNS, ... 2 May 27, 2010 09:38
Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... 2 July 15, 2005 04:15
