-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   Inconsistent addressing between fine and coarse grids (http://www.cfd-online.com/Forums/openfoam/91466-inconsistent-addressing-between-fine-coarse-grids.html)
Radko August 11, 2011 15:37
Hello all,
My OpenFOAM 2.0.0 simulation (rhoSimplecFoam) keeps crashing at random iteration steps with the following error:
[0] --> FOAM FATAL ERROR:
[0] Inconsistent addressing between fine and coarse grids
[0]
[0]    From function GAMGSolver::agglomerateMatrix(const label)
[0]    in file matrices/lduMatrix/solvers/GAMG/GAMGSolverAgglomerateMatrix.C at line 171.
[0]
FOAM parallel run exiting
Google and the forum search do not give any hints in a first search. Can someone tell me the meaning of the error and possibly a quick fix or workaround?
BR, Radko
Tobi September 16, 2012 09:30
I know its 2 years too late but I get the same error after switching my DDR3 memory frequency from 1333 MHz up to 1600 MHz. I tried 5 times the simulation and everytime I got the same error but it did not belong to a certain iteration time.
After switching back to 1333 MHz everything works fine again.
I had a look at my linux behavior and the frequency setted there:
Bios told me: 1600
Linux told me: 1333
Maybe there is something wrong with the linux settings.
If I know new thinks I ll tell it here.
Regard Tobi
nimasam September 16, 2012 10:38
you can use another solver such as GCC or ....
I know it is not solution :D it is to clear the question :D
Tobi September 16, 2012 11:09
I know that I can use a other solver but that`s the reason why the solver aborts every time (ram frequency).
