Home > Forums > OpenFOAM
viewfactor
Old   August 15, 2011, 13:10
Default viewfactor
javad
javad814 is on a distinguished road
thanks for your attention
I can't understand the file named viewFactorDict.
I want to know that what the below parameters mean.
writeViewFactorMatrix true;
writeFacesAgglomeration true;
writePatchViewFactors false;
nFacesInCoarsestLevel 24;
featureAngle 10;
thease are from the tutorials ,sample multiRegionHeaterRadiation.
below is the hole file:
| \\ / O peration | Version: 2.0.0 |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object viewFactorsDict;
topAir_to_heater
featureAngle 10;
topAir_to_leftSolid
nFacesInCoarsestLevel 20;
featureAngle 10;
topAir_to_rightSolid
featureAngle 10;
minX
nFacesInCoarsestLevel 10;
featureAngle 10;
maxY
nFacesInCoarsestLevel 40;
featureAngle 10;
minZ
featureAngle 10;
maxX
featureAngle 10;
maxZ
featureAngle 10;
javad814 is offline   Reply With Quote
Old   August 15, 2011, 14:48
Mirko Vukovic
mirko is on a distinguished road
featureAngle 10;
... stuff deleted
Unfortunately you will have to hit the books, as at least some of the stuff has to do with the numerical method.
As I recall from Fluent, faceAgglomeration has to do with merging multiple face elements. So for example if the body has a surface mesh with 10,000 elements, when you agglomerate them, you may end up with a 1000 elements. This reduces the size of the ViewFactor matrix.
Other than the need to reduce the computational load, agglomeration may have to do with the fact that radiation and conduction/convection are very different problems, and that the mesh necessary for one may be too fine for the other. But I am only guessing.
I need to dig through the code more to understand better where agglomeration is happening (looks like somewhere in faceAgglomerate.C)
Mirko
mirko is offline   Reply With Quote
Old   August 18, 2011, 05:24
Default thanks for your post
javad
below is more information:
path(openFoam 2.0.0): tutorial/heatTransfer/chtMultiRegionSimpleFoam/multiRegionHeaterRadiation/constant/bottomAir/viewFactorsDict
in this sample a new radiation model is used and i must understand how it works and which files are necessary for this model.
to see the results in paraview you must type each region seperatly for example:
paraFoam -region heater
then you can see other regions in paraview as follows:
File>Open
now you can select any region you want,like
multiRegionHeaterRadiation{bottomAir}.OpenFOAM
Thread Tools
Trackbacks are On
Request for help on viewfactor calculation raghav FLUENT 1 November 17, 2008 00:14
Radiation and miscellaneous enhancements vtk_fan OpenFOAM Running, Solving & CFD 6 February 18, 2008 00:49
writing viewfactor file Jonas FLUENT 0 September 1, 2006 06:58
