August 16, 2011, 03:43 |
laplacianFoam blow up
Raph Raggatt
Hello all,
I am struggling with a laplacianFoam case, with just a simple heat transfer case. I have built a mesh in Salome and exported it fine into openfoam, Settings are: Transport Properties: DT = 19e-5 System settings are as tutorial T values: inlet = 773K outlet1 = zeroGradient outlet2 = zeroGradient defaultFaces = zeroGradient Walls = $internalField (273K) I run the case for 100000 steps and for the first 50,000 or so the simulation runs as expected. However, after that it starts going crazy and temperature goes exceedingly high towards the end. I've attached some screenshots and also of Surface with edges to show what the mesh looks like. dz is 0.01. Any ideas why it begins to blow up? Surely the temperature should leave the outlets? Thanks, Rapha |
laplacian |
Mixed BC - heat transfer - laplacianFoam | bhh | OpenFOAM Pre-Processing | 65 | February 7, 2019 09:57 |
Absurd results for blow down sim HELP plz! | MatCFD | OpenFOAM | 0 | May 31, 2011 09:30 |
create own case for laplacianFoam | rahulrp | OpenFOAM Pre-Processing | 6 | April 8, 2010 00:03 |
laplacianfoam with solidification | dakos | OpenFOAM | 1 | November 14, 2009 06:15 |
laplacianFoam and GAMG | karamiag | OpenFOAM Running, Solving & CFD | 0 | May 21, 2009 11:09 |
