-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   Specifying initial data in rhoSimpleFoam (http://www.cfd-online.com/Forums/openfoam/91594-specifying-initial-data-rhosimplefoam.html)
jango August 16, 2011 09:35
4 Attachment(s)
Hello Everybody,
calculating the airflow of a twodimensional dustseparator, I have problems setting up the initial conditions. As you can see in the attached picture, the pipe on the upper left should be the inlet (v = 10 m/s) and the pipe on the upper right should be the outlet (the bottom is closed). I calculate the values according to UG for the cavity example (not knowing exactly if they`re right ??). When I try to run the case, I get the error, that the value for rhoMax in fvSolution is missing. Adding a value for air at 293 K in fvSolution, the following eror message comes up:
--> FOAM FATAL IO ERROR:
[0] wrong token type - expected word, found on line 73 the doubleScalar 1.2041
Now I have the following questions:
1.) Where should I add the (keyword) value for rhoMax, shouldn`t it be added to the constant/thermophysicalProperties file ?
2.) Are the values for k and epsilon correctly calculated ?
I would be very grateful, if anyone could take a look at my case files attached :)
Thank you a lot,
Jan
