-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   changes in rhoSimpleFoam since OpenFOAM version 1.6 (http://www.cfd-online.com/Forums/openfoam/91657-changes-rhosimplefoam-since-openfoam-version-1-6-a.html)
jango August 18, 2011 06:00
1 Attachment(s)
Dear Foamers,
when I try to run an rhoSimpleFOAM (k-e-model, turbulent, compressible) example case in OpenFOAM 2.0, that used to work in version 1.6 I get the following errors:
The first error comes up in the file mut, claiming, that the keyword mutWallFunction is wrong. After changing the Keyword, a similar error occurs in the file alphat for the keyword compressible::alphatWallFunction. After changing this keyword also, the error comes up, that the keyword div((muEff*dev2(T(grad(U))))) is undefined in the fvSolution file. Adding this keyword, I`ve got the error attached error log file.
Hmm, now I'm alittle bit desperate, what else can I do, to get the case running ?
Thank you,
Jan
joel.lehikoinen August 18, 2011 08:56
From what I gather the problem is in your fvSchemes file, more specifically under the gradSchemes keyword. You could try copying the fvSchemes file from a rhoSimpleFoam tutorial case, or if you want to use the same fvSchemes, at least see how it is formatted (what are the changes between your fvSchemes and the tutorial file?). Anyway, it doesn't even seem to be an error but a warning; your calculation seems to have finished okay.
jango August 18, 2011 09:12
Hi Joel,
where can I find the tutorial case in OpenFOAM 2.0 ? In the tut/compressible folder there` s:
rhoCentralFoam
rhoPimpleFoam
rhoPorousMRFLTSPimpleFoam
rhoPorousMRFPimpleFoam
rhoPorousMRFSimpleFoam
rhoSimplecFoam
sonicFoam
sonicLiquidFoam
but no rhoSimpleFoam...
thank you,
Jan
joel.lehikoinen August 19, 2011 03:11
I'd try the fvSchemes file from rhoSimplecFoam first. Looking at the solver descriptions on the FOAM webpage,the only difference between rhoSimpleFoam and rhoSimplecFoam is that the latter uses the SIMPLEC algorithm instead of SIMPLE. I've no idea what's the difference between the two algorithms, but maybe the fvSchemes file works. And even if it doesn't, you don't lose anything by trying.
jango August 19, 2011 10:04
Hi Joel,
thank you very much. Now I could solve the case, copying the fvSchemes and the fvSolution files from the rhoPorousMRFSimpleFoam solver did it for me :-)
have a nice weekend,
Jan
umer.chaudrey September 1, 2011 08:37
Guys, I am trying to implement compressible solver, rhoSimplecFoam. I my controlDict, fvSchemes and svSolution files are exactly similar to the tutorial files for openFoam 2.0.
However I do not have a T boundary field. When I try to run the solution, I get this error. Can anyone please explain what do do with it and how to run it properly. I do have the thermophysicalProperties file in constant folder.
Thanks,
Umer
umer.chaudrey September 1, 2011 08:41
The error
Reading thermophysical properties
Selecting thermodynamics package hPsiThermo<pureMixture<sutherlandTransport<specieT hermo<hConstThermo<perfectGas>>>>>
#0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam200/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam200/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 in "/lib/libc.so.6"
#3 Foam::hPsiThermo<Foam::pureMixture<Foam::sutherlan dTransport<Foam::specieThermo<Foam::hConstThermo<F oam::perfectGas> > > > >::calculate() in "/opt/openfoam200/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
#4 Foam::hPsiThermo<Foam::pureMixture<Foam::sutherlan dTransport<Foam::specieThermo<Foam::hConstThermo<F oam::perfectGas> > > > >::hPsiThermo(Foam::fvMesh const&) in "/opt/openfoam200/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
#5 Foam::basicPsiThermo::addfvMeshConstructorToTable< Foam::hPsiThermo<Foam::pureMixture<Foam::sutherlan dTransport<Foam::specieThermo<Foam::hConstThermo<F oam::perfectGas> > > > > >::New(Foam::fvMesh const&) in "/opt/openfoam200/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
#6 Foam::basicPsiThermo::New(Foam::fvMesh const&) in "/opt/openfoam200/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
in "/opt/openfoam200/platforms/linux64GccDPOpt/bin/rhoSimplecFoam"
#8 __libc_start_main in "/lib/libc.so.6"
Floating point exception
jango September 1, 2011 09:20
Hi Umer,
the floating point exception in the error message may be the result of a division by zero. Try to change all values that should be zero to 1e-16. Maybe that`s it
greetings to the Netherlands,
Jan
umer.chaudrey September 1, 2011 09:34
Hey Jan,
Thank you for your response. I did as you suggested, it did help a little bit. The solution went slightly further but received the error again:
"Create mesh for time = 0
Reading field U
Creating turbulence model
Selecting RAS turbulence model kEpsilon
--> Upgrading k to employ run-time selectable wall functions
Backup original k to k.old
Writing updated k
--> Upgrading epsilon to employ run-time selectable wall functions
Backup original epsilon to epsilon.old
Writing updated epsilon
--> Creating mut to employ run-time selectable wall functions
Writing new mut
--> Creating alphat to employ run-time selectable wall functions
Writing new alphat
kEpsilonCoeffs
Cmu 0.09;
C1 1.44;
C2 1.92;
alphaEps 0.76923;
C3 -0.33;
sigmak 1;
sigmaEps 1.3;
Prt 1;
SIMPLE: no convergence criteria found. Calculations will run for 1000 steps.
Starting time loop
Time = 1
GAMG: Solving for Ux, Initial residual = 0.615417, Final residual = 1.33194e+157, No Iterations 1000
GAMG: Solving for Uy, Initial residual = 0.615411, Final residual = 1.33196e+157, No Iterations 1000
GAMG: Solving for Uz, Initial residual = 0.99242, Final residual = 2.69279e+155, No Iterations 1000
#3 Foam::GaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) in "/opt/openfoam200/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#4 Foam::GaussSeidelSmoother::smooth(Foam::Field<doub le>&, Foam::Field<double> const&, unsigned char, int) const in "/opt/openfoam200/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#5 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMa trix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/opt/openfoam200/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#6 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam200/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam200/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#8 Foam::fvMatrix<double>::solve() in "/opt/openfoam200/platforms/linux64GccDPOpt/bin/rhoSimplecFoam"
#10 __libc_start_main in "/lib/libc.so.6"
#11
asml@flexPC:~/Umer/openfoam200/compressible/comp1$
umer.chaudrey September 1, 2011 09:38
Previous Error
When some values were "0", the error came just after this:
"Create time
Kindly suggest. Can it have anything to do with the fact that I do not have "nuTilda" in my 0 directory as opposed to the one in rhoSimpleFoam tutorial 0 directory. And also have transportProperties in constant directory which are missing in the one in tutorial.
Thanks,
Umer
wyldckat September 5, 2011 14:14
Greetings Umer,
Try installing OpenFOAM 2.0.1. It might be a bug that has already been fixed.
Best regards,
Bruno
umer.chaudrey September 6, 2011 09:32
Problem Still not solved
1 Attachment(s)
Dear Bruno,
Thanks for your reply and feedback. I am using OF 2.0.0. By simplyfing some boundary conditions and removing "0" values to "1e-16", I managed to go just one time step ahead. But it is still not working. As a troubleshooting test case, I am now using a very simple cubical geometry instead of my real one. The error is like this now:
"Create time
Reading field U
SIMPLE: convergence criteria
field p tolerance 0.01
field U tolerance 0.0001
field T tolerance 0.001
field "(k|epsilon|omega)" tolerance 0.001
Starting time loop
Time = 1
smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.992801, No Iterations 1000
smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.765461, No Iterations 1000
smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 0.643294, No Iterations 1000
DILUPBiCG: Solving for h, Initial residual = 0.539879, Final residual = 0.00355726, No Iterations 1
GAMG: Solving for p, Initial residual = 1, Final residual = 3.16783e+61, No Iterations 1000
time step continuity errors : sum local = 8.02225e+61, global = -2.82469e+61, cumulative = -2.82469e+61
rho max/min : 1.19028 1.14028
smoothSolver: Solving for epsilon, Initial residual = 1, Final residual = 0.184692, No Iterations 1000
smoothSolver: Solving for k, Initial residual = 1, Final residual = 0.151554, No Iterations 1000
ExecutionTime = 0.11 s ClockTime = 0 s
Time = 2
smoothSolver: Solving for Ux, Initial residual = 0.232692, Final residual = 0.0764661, No Iterations 1000
smoothSolver: Solving for Uy, Initial residual = 0.387239, Final residual = 0.126151, No Iterations 1000
smoothSolver: Solving for Uz, Initial residual = 0.187553, Final residual = 0.114679, No Iterations 1000
DILUPBiCG: Solving for h, Initial residual = 1, Final residual = 0.0202837, No Iterations 2
#4 Foam::hPsiThermo<Foam::pureMixture<Foam::sutherlan dTransport<Foam::specieThermo<Foam::hConstThermo<F oam::perfectGas> > > > >::correct() in "/opt/openfoam200/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
in "/opt/openfoam200/platforms/linux64GccDPOpt/bin/rhoSimpleFoam"
#6 __libc_start_main in "/lib/libc.so.6"
I have used both the fvschemes for rhoSimplecFoam and rhoMRFSimpleFoam (as it was being discussed by some other users in some other thread)
I have attached my case folder with this message, please kindly have a look at the case and advise me.
I have simulate evacuation of an air chamber through a pipe hole and do some optimization. With incompressible turbulent conditions, I can simulate it successfuly. But for more accuracy and for my requirements I need to do it in compressible turbulent case, hence I think rhoSimpleFoam is the solver which I can use only.
Please do advise, Thanks. Will appreciate that. My work is stuck big time.
Regards,
Umer
MartinB September 6, 2011 10:30
Hi Umer,
just refine your mesh a little bit, and it will run. For example with:
refineMesh -overwrite
Then start rhoSimpleFoam.
You may want to set the BC for T to zeroGradient at the outlet, too.
Good luck
Martin
umer.chaudrey September 7, 2011 03:28
Hey Martin,
Thanks a lot for your feedback and guidance. Yes this particular simple test case is working now after your suggestion.
I will now move on to my real case and then see if it works.
Regards,
Umer
