[Commercial meshers] Face ordering problem for nonrectangular cyclic boundary conditions
Old   September 19, 2008, 11:08
Default Face ordering problem for nonrectangular cyclic boundary conditions
Markus Weinmann
cfdmarkus is on a distinguished road
I am trying to simulate the flow in a planar channel with streamwise periodic hills on the lower wall. The flow domain has planar, cyclic boundary conditions in streamwise and spanwise directions.
Using cyclic boundary conditions in streamwise direction works just fine, however, a face ordering problem exists when I use cyclic boundaries in spanwise direction.
face 0 area does not match neighbour 722 by 37.8947% -- possible face ordering problem.
patch:CYCLICSYMM my area:0.00280653 neighbour area:0.00411868 matching tolerance:0.001
Mesh face:41515 vertices:4((0 0.0526316 0) (0.0526316 0.0540166 0) (0.0526316 0 0) (0 0 0))
Neighbour face:42237 vertices:4((1 0 0) (1 0.0789474 0) (1.05263 0.0775623 0) (1.05263 0 0))
Rerun with cyclic debug flag set for more information.
From function cyclicPolyPatch::calcTransforms()
in file meshes/polyMesh/polyPatches/constraint/cyclic/cyclicPolyPatch.C at line 150.
For the same case with the hills removed (simple planar channel flow with cyclic BC in streamwise and spanwise direction) this problem does not exist. The only difference between the two cases is that without the hills in place, the faces in spanwise directions are rectangular and with the hills in place, the faces are non-rectangular.
I also tried to export the grid with two separate boundary faces in spanwise direction and then tried to combine the faces into a cyclic patch using createPatch. Unfortunatley, this always resulted in a crash of createPatch.
Does anybody know why the face ordering problem suddenly arises when I am using non-rectangular patches as cyclic BC and more importantly, how can I solve this face ordering problem?
Best regards,
Markus
cfdmarkus is offline   Reply With Quote
Old   September 26, 2008, 11:13
Default I have the same problem, its a
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
I have the same problem, its always when I am trying to use a 3D mesh with a cyclic bc. Try renumberMesh and see what happens. Although I was not able to have any better luck when I did this. I did also try the createPatch utility and it hasn't worked in OF 1.5 for me yet, but did in 1.4.1-dev.
chegdan is offline   Reply With Quote
Old   September 28, 2010, 12:45
maysmech's Avatar
maysmech is on a distinguished road
i have same problem
maysmech is offline   Reply With Quote
Old   August 17, 2011, 15:07
Pam
prameelar is on a distinguished road
Check with the vertices values.. there is a difference in betwwen these points.
"4((0 0.0526316 0) (0.0526316 0.0540166 0) (0.0526316 0 0) (0 0 0))
4((1 0 0) (1 0.0789474 0) (1.05263 0.0775623 0) (1.05263 0 0)) ".
Hope it helps.
Pam
prameelar is offline   Reply With Quote
area does not match neighbour by ... % -- possible face ordering problem St.Pacholak OpenFOAM 10 February 7, 2024 21:50
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 08:44
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
