August 25, 2011, 15:32 |
error running potentialFoam
Jubayer
Location: The University of Western Ontario, London, Ontario
I am getting the following error while running potentialFoam. Can someone please tell me the probable reason for that. FOAM aborting #0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam171/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::error::abort() in "/opt/openfoam171/lib/linux64GccDPOpt/libOpenFOAM.so" #2 Foam::Ostream& Foam:perator<< <Foam::error>(Foam::Ostream&, Foam::errorManip<Foam::error>) in "/opt/openfoam171/applications/bin/linux64GccDPOpt/potentialFoam" #3 Foam::Istream& Foam:perator>><Foam::Vector<double> >(Foam::Istream&, Foam::List<Foam::Vector<double> >&) in "/opt/openfoam171/applications/bin/linux64GccDPOpt/potentialFoam" #4 Foam::Field<Foam::Vector<double> >::Field(Foam::word const&, Foam::dictionary const&, int) in "/opt/openfoam171/applications/bin/linux64GccDPOpt/potentialFoam" #5 Foam::fvPatchField<Foam::Vector<double> >::adddictionaryConstructorToTable<Foam::fixedValu eFvPatchField<Foam::Vector<double> > >::New(Foam::fvPatch const&, Foam:imensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/openfoam171/lib/linux64GccDPOpt/libfiniteVolume.so" #6 Foam::fvPatchField<Foam::Vector<double> >::New(Foam::fvPatch const&, Foam:imensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/openfoam171/applications/bin/linux64GccDPOpt/potentialFoam" #7 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::GeometricB oundaryField(Foam::fvBoundaryMesh const&, Foam:imensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/openfoam171/applications/bin/linux64GccDPOpt/potentialFoam" #8 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::readField(Foam::dictionary const&) in "/opt/openfoam171/applications/bin/linux64GccDPOpt/potentialFoam" #9 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::readField(Foam::Istream&) in "/opt/openfoam171/applications/bin/linux64GccDPOpt/potentialFoam" #10 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::fvMesh const&) in "/opt/openfoam171/applications/bin/linux64GccDPOpt/potentialFoam" #11 in "/opt/openfoam171/applications/bin/linux64GccDPOpt/potentialFoam" #12 __libc_start_main in "/lib64/libc.so.6" #13 in "/opt/openfoam171/applications/bin/linux64GccDPOpt/potentialFoam" Aborted |
August 25, 2011, 15:37 |
Jubayer
The first portion of the error...
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.7.x | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 1.7.x-3776603e4c6c Exec : potentialFoam Date : Aug 25 2011 Time : 15:13:51 Host : pkgst1 PID : 7636 Case : /home/sysadmin/OpenFOAM/sysadmin-1.7.1/run/tutorials/basic/potentialFoam/Solarpanels nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading field p Reading field U --> FOAM FATAL ERROR: Attempt to cast type N4Foam5token8CompoundINS_4ListIdEEEE to type N4Foam5token8CompoundINS_4ListINS_6VectorIdEEEEEE From function dynamicCast<To>(From&) in file /home/opencfd/OpenFOAM/OpenFOAM-1.7.x/src/OpenFOAM/lnInclude/typeInfo.H at line 93. |
August 25, 2011, 15:47 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Jubayer,
There is some strange crazy stuff going on there, which is why it's crashing! #2 and #3 from the 1st post indicate that it crashed when it was trying to output an error message (#2), which occurred when reading from some file (#3). From the 2nd post, there is an error that the compiler would never have allowed to happen! To top that, it looks like you have two versions of OpenFOAM overlapping each other! Namely 1.7.1 and 1.7.x! This should never happen... unless one knows what one is doing! Additionally, running a tutorial that is not from the official list of tutorials will increase the probability of error! "Solarpanels" is not a tutorial from the list of tutorials distributed with OpenFOAM! Best regards, Bruno
January 26, 2012, 14:42 |
Hi, I am facing a similar problem. Did anyone solve this strange error?
--> FOAM FATAL ERROR: Attempt to cast type N4Foam5token8CompoundINS_4ListIdEEEE to type N4Foam5token8CompoundINS_4ListINS_6VectorIdEEEEEE |
January 26, 2012, 15:42 |
Jubayer
Hi blackbirdinapie,
potentialFoam only works if the velocity and pressure are fixedValues, not a profile. For my case, I had a velocity profile at the inlet which caused the error. Hope this helps. Jubayer |
March 28, 2018, 05:16 |
problems with funkyDoCalc for groovyBC type inlet
Felix S
Rep Power: 8 |
I recieve the same Error Code:
Attempt to cast type N4Foam5token8CompoundINS_4ListIdEEEE to type N4Foam5token8CompoundINS_4ListINS_6VectorIdEEEEEE I defined one 0/U file with different variables to change the inlet boundary condition. Otherwise I use the same simulation every time. The problem is that funkyDoCalc works for most of the results while a few of them are causing this error. For me there is no resonable pattern when the error occurs. |
March 28, 2018, 10:04 |
I found the source to the error
Felix S
Rep Power: 8 |
in my case something strange happens for some of the inlet bcs. Apparently the groovyBC inlet information is taken over into the result-files. Converting them into ascii shows that the groovyBC inlet suddenly has Code:
boundaryField { inpipe { refValue uniform (0 3.347407 6.694814); refGradient uniform (0 0 0); valueFraction uniform 1; value uniform (0 3.347407 6.694814); ... The problem with some of my calculations though is that the refValue and refGradient become lists of scalar values except of vectors. This causes funkyDoCalc to crash with the mentioned error. I solved the problem for my purporses by putting something uniform like in the example above since my evaluated patch has nothing to do with the inlet conditions. edit: it is also possible to change the inlet type from groovyBC to fixedValue. That is an easy search and replace approach and the solution-field stays correct. I am still interested of how the error occured in the first place. I also had troubles with reconstructPar for the exact calculations, which was made possible by deleting the groovybc.so from the libs in the controlDict (that is a known problem: https://bugs.openfoam.org/view.php?id=1234). |
error, potentialfoam |
Using potentialFoam with simpleBuoyantFoam | lasb | OpenFOAM Running, Solving & CFD | 5 | August 28, 2015 12:32 |
Boundary conditions for potentialFoam | doubtsincfd | OpenFOAM | 7 | May 17, 2011 04:11 |
potentialFoam around a sphere ; mesh by Gmsh | eliam | OpenFOAM Running, Solving & CFD | 12 | January 26, 2011 03:02 |
potentialFOAM with non-zero pressure @outlet | muellea | OpenFOAM | 2 | September 12, 2010 23:34 |
PotentialFoam fails | bastil | OpenFOAM Running, Solving & CFD | 0 | April 17, 2009 09:43 |
