-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   rhoCentralFoam Solver (http://www.cfd-online.com/Forums/openfoam/92090-rhocentralfoam-solver.html)
venkataramana September 1, 2011 20:52
Dear Foamers,
I am unable to understand the code given in the RhoCentralFoam.C i mean the working procedure, but in the user guide given about pisoFoam and IcoFoam. Where should I find the information about the code like " reconstruct(rho)"
thanks in advance.
alberto September 6, 2011 22:06
There is a paper on the solver:
Christopher J. Greenshields, Henry G. Weller, Luca Gasparini and Jason M. Reese, Implementation of semi-discrete, non-staggered central schemes in a colocated, polyhedral, finite volume framework, for high-speed viscous flows, INTERNATIONAL JOURNAL FOR NUMERICAL METHODS IN FLUIDS, Int. J. Numer. Meth. Fluids 2010; 63:1–21
For the definition of reconstruct: ~/OpenFOAM/OpenFOAM-2.0.x/src/finiteVolume/finiteVolume/fvc/
I hope this helps.
venkataramana September 7, 2011 02:16
Dear Alberto Passalacqua thank you very much for your kind information
Regards,
buaawangwei April 8, 2012 06:06
Hi alberto,
I want to know that rhoCentralFoam is a steady solver or a transient solver?Thank you
alberto April 8, 2012 16:49
It is a transient solver. You can check that easily by looking at the tutorials.
nsreddysrsit April 9, 2012 14:54
hi
There are two types of solvers in openFoam for compressible flows. For example RhoSimpleFoam and RhoCentralFoam. The solution methods (algorithm) are different for the above two solvers. How to choose the solver. And what are all the parameters we have to consider while selecting the solvers.
Regards,
alberto April 9, 2012 17:10
Regards,
The rhoSimpleFoam solver is a pressure-based solver for steady state laminar and turbulent (RAS) flows. An unsteady version is available in rhoPimpleFoam.
The rhoCentralFoam solver uses a density-based approach with central schemes, and it solves the unsteady equations.
The choice of the solver depends on the type of flow you have:
- Steady/unsteady?
- High Mach number (density based approach) / low Mach number (pressure-based approach)?
Best,
nsreddysrsit April 10, 2012 00:10
hi
hi alberto,
Thanks for reply,
How to find the which solver is the best for different range of Mach Numbers, and is there any limitation for any solver for prescribed Mach Mumber, How to find that. How the results are varies if i use pressure based solvers and density based solvers if i use same problem. what are all the factors we have to consider.
Regards,
alberto April 10, 2012 20:02
Originally Posted by nsreddysrsit (Post 353869)
hi alberto,
Thanks for reply,
Regards,
I think you should really refer to the literature to understand the limitations of each approach, since special formulations of each of them are available and aim at extending their range of applicability.
If you have a specific problem in mind, you should provide details about it, so that the question is specific.
sahas April 19, 2012 08:19
Hallo!
I am using rhoCentralFoam for my transsonic laminar problem. May be I am wrong, but the one of the main feature of rhoCentralFoam I think is using of fully conservative scheme, so the main conservative laws (for example, for energy) are always preserved. I tried sonicFoam and rhoSimpleFoam and found that there were problems with temperature distributions (such problems were discussed on the forum).
As for rhoPimpleFoam I cannot get it worked for my case =(
So I recommend use of rhoCentralFoam for the problems with Mach number > ~1
immortality August 26, 2013 11:29
Hi
what does the lines for momentum solving in this solver mean?
// --- Solve momentum
        solve(fvm::ddt(rhoU) + fvc::div(phiUp));
        U.dimensionedInternalField() =
            rhoU.dimensionedInternalField()
          /rho.dimensionedInternalField();
        U.correctBoundaryConditions();
        rhoU.boundaryField() = rho.boundaryField()*U.boundaryField();
        volScalarField rhoBydt(rho/runTime.deltaT());
        if (!inviscid)
            solve
                fvm::ddt(rho, U) - fvc::ddt(rho, U)
              - fvm::laplacian(muEff, U)
              - fvc::div(tauMC)
            rhoU = rho*U;
whats the mathematical(CFD)form of the equation:
              - fvc::div(tauMC)
