segmentation fault
I run cases for liquid film recently using interDyMFoam. There's no problem when I run the cases, but when I try to reconstruct fields, it shows the following error: #0 Foam::error::printStack(Foam::Ostream&) in "/home/huxiaoxi/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::sigSegv::sigSegvHandler(int) in "/home/huxiaoxi/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libOpenFOAM.so" #2 __restore_rt at sigaction.c:0 #3 Foam::objectRegistry::checkOut(Foam::regIOobject&) const in "/home/huxiaoxi/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libOpenFOAM.so" #4 Foam::regIOobject::~regIOobject() in "/home/huxiaoxi/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libOpenFOAM.so" #5 Foam::IOList<int>::~IOList() in "/home/huxiaoxi/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linux64GccDPOpt/reconstructPar" #6 Foam::processorMeshes::read() in "/home/huxiaoxi/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linux64GccDPOpt/reconstructPar" #7 Foam::processorMeshes::readUpdate() in "/home/huxiaoxi/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linux64GccDPOpt/reconstructPar" #8 main in "/home/huxiaoxi/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linux64GccDPOpt/reconstructPar" #9 __libc_start_main in "/lib64/libc.so.6" #10 Foam::regIOobject::writeObject(Foam::IOstream::str eamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/home/huxiaoxi/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linux64GccDPOpt/reconstructPar" Segmentation fault Can anyone help me? Thanks. Xiaoxia |
segmentation fault
yes, I did.
Next question: are you reconstructing all time-steps at once (that is another thing that doesn't work as far as I remember). Can't tell from whatyou posted if the problem occured during the reconstruction of the first time-step or later If its not that I can only tell you what I tell all people that have a segfault: Compile a Debug-version of OF. Then the dump will also show line numbers and things get interesting |
How can I compile a debug-version of OF? By the way, I am using the version 1.7.1? Is it possible to have the bug for this version?
