September 6, 2011, 19:29 |
Discretization
Rep Power: 14 |
Hi Guys
As you all may know, the form of the discretized momentum equation that have been used in OpenFOAM's icoFoam solver is based on the general Scalar Transport equation which has term "del.(U Phi)" and has been discretized in the following way "fvm :: div(phi, U)" My question is that how can I discretize it based on familar N.S. equation form which includes U.del(Phi). I tried "U & (fvc::grad(phi))" but it produced the follwoing error "no match for ‘operator&’ in ‘Foam:perator+(const Foam::tmp<Foam::fvMatrix<Type> >&, const Foam:imensionedField<Type, Foam::volMesh>&)" I would appriciate your commments. |
September 7, 2011, 17:30 |
#2 | |
Daniel P. Combest
div(UU) = U & grad(U) + U*div(U) for incompressible flow at a low residual...div(U) goes to zero and div(UU) = U & grad(U) so...div(UU) is considered the conservative form of the equation. hope this helps. Dan |
September 7, 2011, 17:56 |
Rep Power: 14 |
Daniel
Thank you for your help. |
Spatial vs Angular Discretization in DO radiation model | renaldi | FLUENT | 1 | February 16, 2024 08:47 |
Convergence and discretization | karananand | FLUENT | 3 | August 29, 2010 06:07 |
Discretization and convergence | karananand | Main CFD Forum | 0 | August 4, 2010 16:19 |
Space and time discretization of Euler equation | Hooman | Main CFD Forum | 2 | June 6, 2010 08:30 |
Low-Re and second order discretization | Ralf | Siemens | 1 | May 11, 2006 10:16 |
