Home > Forums > OpenFOAM
error when running icoFoam
Old   March 16, 2012, 20:46
calim_cfd's Avatar
mauricio
calim_cfd is on a distinguished road
glad you solved the mesh problem!
about the physics.. i guess you didn't send all case files..anyway i got the zip file at my work and i tried to do a quick run but there were stuff missing for the solver you had chosen..
anyway i tried your case again and i got the error
Checking geometry...
    Overall domain bounding box (-0.0063 -0.0063 0) (0.0063 0.0063 0.0098)
    Mesh (non-empty, non-wedge) directions (1 1 1)
    Mesh (non-empty) directions (1 1 1)
    Boundary openness (-3.47963e-17 1.89701e-16 1.21815e-16) OK.
 ***High aspect ratio cells found, Max aspect ratio: 1.10117e+193, number of cells 35000
  <<Writing 35000 cells with high aspect ratio to set highAspectRatioCells
    Minumum face area = 2.7986e-08. Maximum face area = 2.19687e-07.  Face area magnitudes OK.
    Min volume = 2e-300. Max volume = 2e-300.  Total volume = 7e-296.  Cell volumes OK.
#0  Foam::error::printStack(Foam::Ostream&) in "/home/mjcaliri/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigFpe::sigHandler(int) in "/home/mjcaliri/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2   in "/lib/x86_64-linux-gnu/libc.so.6"
#3   in "/lib/x86_64-linux-gnu/libm.so.6"
#4  acos in "/lib/x86_64-linux-gnu/libm.so.6"
#5  Foam::primitiveMesh::checkFaceOrthogonality(bool, Foam::HashSet<int, Foam::Hash<int> >*) const in "/home/mjcaliri/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
 in "/home/mjcaliri/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/bin/checkMesh"
#8  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
Floating point exception
when checking the mesh... it seems you got a very small element which is messing up everything... so your blockmesh file should have at least 1 block with wrong vertices..
if you built the mesh somewhere else i guess the case ran fine
gj
Best Regards
/calim
"Elune will grant us the strength"
calim_cfd is offline   Reply With Quote
Thread Tools
Trackbacks are On
Valgrind claims invalid free when running icoFoam from OpenFOAM 1.6-ext andrewryan OpenFOAM Bugs 3 March 30, 2011 08:00
Suse10 FoamX problem frank178 OpenFOAM Installation 6 January 14, 2010 05:18
problem when running icoFoam on a complex shape flow field wendywu OpenFOAM 1 May 20, 2009 23:40
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 10:38
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 07:52
